11.5 rear axle
Old May 29, 2003 | 01:41 PM
Ram lon ON's Avatar
11.5 rear axle
My rear axle was 3 pints low.MY question would be what is <br>the total capacity of the11.5 when filled to the normal amount. I could not find it in my owners manual.3 PINTS <br>could be alot if the total is a small amount. Thank You. ???
Old May 29, 2003 | 05:05 PM
pwabbott's Avatar
Re:11.5 rear axle
Ram lon ON,
Don't fill rear axle yourself, take it to a dealer and have them fill it. If they have a work order showing they filled you have documentation of a warranty problem. Sounds as though you are at least one quart low. Some of us have had to have ring and pinion gears replaced. Some of the low GL-5 problems may not show up for 20K-30K miles.
I have attached the page from the 2003 Dodge Service Manual which shows the Capacities. 11.5 axle is 7.62 pints or 3.81 quarts
Three pints low is marginal. I lost pinion bearings at 4 pints low in 2000 miles, a real bummer.
Wantabe lost his whole rear axle and auto tranny was tweaked badly at 65 mph. One wheel hub froze and twisted off.
Old May 29, 2003 | 07:10 PM
Ram lon ON's Avatar
Re:11.5 rear axle
Thank you SIERRA Phil, I did take it to the dealer nearest me<br>and they put 3 pints in it. They wouldnt or couldnt tell me how<br>many it did hold so I thank you very much. Now I am going to<br>fax the invoice showing the work done to ,the Dealership that <br>I bought my truck from. I had told them to make sure all fluid<br>levels were good because I had a 200 mile trip home.They <br>asured me everything was done when they gave me the Keys <br>with all the final paper work.<br> 3 pints is darn near half what it takes so I am am going to <br>get HOT with them. Thank You.
Old May 30, 2003 | 06:20 AM
spots's Avatar
Re:11.5 rear axle
Wonder where wantabe ever ended up??<br>My truck also siezed the left wheel brgs at 400k. New axle assy and at 16k all is good. The dealer would not say the rear end was low but I suspect it was.
Old May 30, 2003 | 06:46 AM
bulabula's Avatar
Re:11.5 rear axle
[quote author=spots link=board=20;threadid=15289;start=0#143765 date=1054293643]
[/quote]
400 thousand miles? On an '03 when first wheel bearing siezed? 16 thousand on the second axle assembly? Man, I haven't even got 11k on mine, and I bought it in November. Do you ever get out of the cab?
My gut tells me that DC &quot;asked/persuaded&quot; wantabee to keep his mouth shut. Seems he disappeared quickly off both boards. Or maybe his lawyers recommended he keep his mouth shut so not to possibly jeapordize his position in the future.
Old May 30, 2003 | 10:46 AM
pwabbott's Avatar
Re:11.5 rear axle
My last communication w/Wantabee was about 11/13-15, direct message. Hunter had one from him about the same time indicating he was having surgery. Then even threads disappeared from this forum. Maybe D-C as a condition of settlement with him had him agree to stay off forums. He could have reported to some of us regarding his recovery from surgery since that was unrelated to his truck problems. ??? ??? ???
Old May 30, 2003 | 06:09 PM
cp's Avatar
cp
Re:11.5 rear axle
[quote author=Ram lon ON link=board=20;threadid=15289;start=0#143651 date=1054253427]<br>I had told them to make sure all fluid<br>levels were good because I had a 200 mile trip home.They <br>asured me everything was done when they gave me the Keys <br>with all the final paper work.<br> 3 pints is darn near half what it takes so I am am going to <br>get HOT with them. Thank You.<br>[/quote]<br><br>I don't blame you for being hot, but don't blow up at them right off the bat. Give them a chance to make you happy--then, if they don't, BLOW UP. You've got every reason.
Old May 30, 2003 | 10:51 PM
emjay's Avatar
Re:11.5 rear axle
The problem with low oil is that it can shorten the life of the bearings and gears, and you wont find that out until it's too late. The best way to tell, IMHO, is disassemble and look for scored/discolored rollers and races. It's not too difficult a job. If your diff bearings look ok, there's a good chance that your pinion bearings are probably ok, too. Also, the condition of the lube, and presence of silver-colored flakes is a good indicator of bearing trouble.
Old May 31, 2003 | 06:50 AM
spots's Avatar
Re:11.5 rear axle
[quote author=bulabula link=board=20;threadid=15289;start=0#143781 date=1054295179]<br>[quote author=spots link=board=20;threadid=15289;start=0#143765 date=1054293643]<br>My truck also siezed the left wheel brgs at 400k. New axle assy and at 16k all is good. The dealer would not say the rear end was low but I suspect it was.<br>[/quote]<br><br>400 thousand miles? On an '03 when first wheel bearing siezed? 16 thousand on the second axle assembly? Man, I haven't even got 11k on mine, and I bought it in November. Do you ever get out of the cab?<br><br>My gut tells me that DC &quot;asked/persuaded&quot; wantabee to keep his mouth shut. Seems he disappeared quickly off both boards. Or maybe his lawyers recommended he keep his mouth shut so not to possibly jeapordize his position in the future.<br>[/quote]<br><br>No sorry for the confusion 400 miles. New diff. Now has 17k on it. All is fine with the diff.<br>Fingers were typing faster than my brain was a calculatin....
Old May 31, 2003 | 10:29 AM
pwabbott's Avatar
Re:11.5 rear axle
spots,<br>&quot;Fingers were typing faster than my brain was a calculatin.... &quot; FleetFingeredBob and I call that a &quot;Senior Moment&quot;, excusable at any age. <br><br>&quot;I may have Snow on the Roof, however there's still Fire in the Furnace.&quot;
Old May 31, 2003 | 04:35 PM
FiverBob's Avatar
Re:11.5 rear axle
[quote author=Sierra Phil link=board=20;threadid=15289;start=0#144195 date=1054394995]<br>spots,<br>&quot;Fingers were typing faster than my brain was a calculatin.... &quot; FleetFingeredBob and I call that a &quot;Senior Moment&quot;, excusable at any age. <br><br>&quot;I may have Snow on the Roof, however there's still Fire in the Furnace.&quot; <br>[/quote]<br><br>Seems to take a lot more fuel to keep it running nowadays, there old friend - - ehhh, that is you over there isn't it, Sierra? Move a little closer - - forgot my specs. <br><br>OldGoatBob
Old May 31, 2003 | 07:10 PM
pwabbott's Avatar
Re:11.5 rear axle
YeOldGoatBob,
Turned the A/C on high, fuel mileage went south. Did you see it goin past White Ghost. We have a three day breather, Sacramento is headed for the hundreds Monday . we are usually 10-12 degs cooler. but have to take Purty Almond town there to suffer on Mon Eve. Gets a Flywheel and Clutch Transplant on Tues, Woopie! D-C says do what is necessary to solve the shakin. MI doesn't know this is Earthquake Country. This could put Cal Tech's Seismology Lab out of business.
ShakinAndAWaitin Phil
Old Jun 1, 2003 | 05:31 AM
Drafter's Avatar
Re:11.5 rear axle
Sierra Phil,<br><br>Wish I had thought about forcing the dealer to top off the diff's. I called them about the fluid levels being at the very bottom of spec and they said it was in spec and fine and not to worry about it. I ended up buying an expensive quart from them and put a pint in each diff case. At the time I bought the quart it was the only one they had in stock. The levels are now that much higher and I kept the sales receipt so I quess I have that going for me. I've been meaning to get another quart and put an addtional pint in each diff for peace of mind.
nvr-enuf
Jan 30, 2014 06:56 PM
ian515
Jul 24, 2009 03:22 PM
mudwisr2
Feb 22, 2008 11:51 AM
MX429
Aug 20, 2006 06:41 PM
Paul Winey
Jun 22, 2004 08:09 AM
