#1 injector bad what is the best way to fix
my dealer says my #1 injector is bad looking for suggestions on a fix is there only there option on replacing with a new stock injector or should i go the aftermarket route.not sure what normally fails on these injectors is it usually the tip that cracks or does the main part of the injector fail.they told me 800+can for a new one so just looking for other options.from what i have read the aftermarket injectors are just a new tip.thanks shane
I think aftermarket F1's are around 1000-1200 for all 6......if I drop one I will probably just throw some F1's in mine...especially if you are out of warranty aftermarket for sure
Just a quick question??? Whats your millage on truck and what year truck???
If truck is under 100,000 miles should be warranty. Rule is under 100K under 5 year no deductable (Dodge - Cummins engine warranty) under 100K over 5 years to 7 years $100 deductable. Now I don't know about Canadian warranty but think it should be comprable to the US warranty. If in doubt call Dodge customer care line with the last 8 digits of your VIN and they can let you know what your warranty was/is. If over the 100K or 7 years then guess I'd seriously look at some type of after market injector and just replace all 6....
Good luck.....
Good luck.....
most of the dealers have a shortage on new injectors. when mine went bad the dealer said upto 4 weeks before I could get my truck back.ANd then same crappy injector would go back in it. Sent them to F1 had them back in a week and a half with better tips
The $1200 on the aftermarket injectors is just for the tips. Most of the time an injector goes the body cracks. Just go to Cummins and pay $400 for one and replace it yourself if you don't have a warranty. I can do one in an hour and a half.
Edit: What did Don charge for the core charge on the bad injector?
yup iam at 119000km but iam fighting with the dealer for them to replace it because i just bought it 3months ago.but so far they are just saying they will see what they can do so iam looking for other options at this time until they give me a answer but its not looking like they are goin to do anything at this time.my dealer has 2 injectors in stock & they are 800$ each & that does not inclued install.
$800 for one stock injector is a joke!!!
Relax, that is $800 Canadian which is about $34 US.
If you are not mechanically inclined, and they won't/can't repair under warrantee, take it to a good independent shop and have them replace all 6 with F1s. You can check them out at http://www.f1diesel.com/injectorsecho.html
not sure why my sig line is not working but i have a o3 & injector coverage is gone at 112000km in Canada.oh & if you have not looked lately our dollars are almost even these days was looking for a cheaper solution at this time but if it comes down to it i may go that way for the little cost diff.is there any place that you can get rebuild ones.thanks
i got a injector for a good price after remembering a buddy has a cummin dealer called him & got one at cost.iam going to install myself how do i find injector # 1 are they marked or is it just 1-6 front to back or back to front.
according to my warranty book motor is covered for 160k km or 7yrs. 5yrs/160k km no deductable, yr 6&7/160k km $100 deductable. did the 03 have a shorter coverage term?
