08+ steering upgrade complete - someone double check my work?
5 Attachment(s)
(Probably should've put this in the drivetrain forum, sorry!)
I just finished the 08+ upgrade. Everything went smooth, except for that darn pitman arm and only ordering 1, not 3, tie rod nuts (had to go to the dealership today). Setup with about 1/16" toe in. Just took it for a test drive and love the response it gives. Small steering inputs now translate to movement of the truck in the direction of the input. With the old setup, you could wiggle the wheel back and forth and the response was very weak (combo of the Y setup as well as old tre's). I've read the warnings of making sure the tie rod end is to be level with the steering arm. I took some pictures below of all my tie rod ends, can someone confirm they look good? Appreciate your input! Driver's side: Attachment 54275 Passenger side: Attachment 54276 Pitman arm (angle of the pic shows the stud on the tierod, but it's not): Attachment 54277 Drag link & track bar: Attachment 54278 Pitman arm removal: Attachment 54279 |
Looks good!
And I guess that IS one way to remove a pitman arm [laugh] |
(Post 3185233)
Looks good!
X2- looks good to go.
I had the same issue with the pitman.... |
What is the benefit of this mod? Should I do mine??? Being mine is a 2wd?
Installation looks good. I did mine last week and had to heat my pitman arm for removal.
Originally Posted by DragonSlayer
(Post 3185386)
Thanks for posting, this will help with my installation!
Originally Posted by jimbo486
(Post 3185411)
No need since the 2wd trucks have rack and pinion steering.
You mind giving info on where you got your setup from? Looking to do this myself but wasn't sure where to purchase from.
Thanks! |
Originally Posted by Hemi6677
(Post 3185824)
Thanks! http://www.factorymoparparts.com/ When searching that website for the part numbers, use the "all categories" option in order to find your parts. Here's a link to the first part number: http://www.factorymoparparts.com/52122362af.html Part numbers & quantities: P/N 52122362AF, Quantitiy 1, $247.25 (drag link, crossover, tierod end assembly) P/N 68039930AA, Quantitiy 1, $29.73 (pitman arm) P/N 6505623AA, Quantitiy 3, $1.63/ea (tierod nuts) Total after shipping was $320. Ordered online on Saturday, billed/shipped Monday, arrived Thursday. Only thing it does not come with is a steering stabilizer, but it does come with the stud on the tierod to mount the stabilizer. There is another kit on a different website that provides a Skyjacker stabilizer and all-of-the-above items for $336, but it was a lot more for shipping to my address so I decided against it (your address may be cheaper to ship to...http://www.moparsupercenter.com/dodg...afpk362af.html). I've been driving with no stabilizer and it's been fine. I will add one but I've put on a few hundred miles without it and it's just fine. |
Pitman Arm
Does the Pitman arm have to be replaced? I was told by local autoparts that it was not required. Please clarify.
Thx. |
2 Attachment(s)
Originally Posted by opofus
(Post 3185962)
Thx. Found these pictures from someone else to help show the issue between the different pitman arms... Upgraded steering steering WITHOUT upgraded pitman... Attachment 54265 Upgraded steering WITH upgraded pitman... Attachment 54266 |
Seeing those picture, I wouldn't hesitate to upgrade the pitman. More than likely just perspective, but the new drag link end looks awfully close to the oil pan.
Moved it for you.
Nice work on the upgrade. I did my entire front end over with Raybestos parts. |
