07 5.9 oil pressure issues
Off and on for a while when you start my truck and let it run a minute the oil pressure dropped to zero and check guages light came out. I shut it off then restarted and everything is fine. Yesterday it kept doing it. Now when you try and start the truck it tries to turn over but just whines like the starter isn't engaged. Any ideas I'm lost and do t really know where to start. I did check the batteries and both are good.
Cummins Guru
I would try mechanical oil pressure gauge. Have someone crank over engine see if crankshaft is turning, if not you may have a bad starter.
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
