06 manual transmission leak
Old 11-27-2009, 08:24 PM
Rich Baars's Avatar
After 46 k miles, I have a fluid leak at the front of the manual transmission. What does it take to fix it, does it need immeadiate attention?
Old 11-27-2009, 08:34 PM
mitternocht's Avatar
It could be the shift book leaking. When they crack and split oil will run down the sides of the trans making it look like you have a bigger problem than you think. Hopefully that it is what it is anyway!
Old 11-27-2009, 08:44 PM
NickBeek's Avatar
Are you sure it is trans fluid? If it is near the front of your trans check the little hose in this picture, the clamps tend to need tightening every fall, it will leak and run down the block right neat the front of the trans.
When my shift boot was leaking it ran down the back of the trans. The boot is located under the console in the truck. This is not hard to replace.
Old 11-28-2009, 09:06 AM
carl48's Avatar
if it is the shift boot, now is the time to add the extra quart of atf. also the dual mass flywheel causes problems that starts the front seal to leak. you need to chang it out to the south bend kit anyway. it will never make a 100,000 miles
Old 11-28-2009, 09:12 AM
Jeff in TD's Avatar
06's are famous for that coolant leak. Mine dripped off the front of the bellhousing, and since Mopar dies their HOAT red...
Old 12-01-2009, 08:58 PM
Rich Baars's Avatar
Yes, it has an oily feel to the leak which is at the front of the tranny. It feels/looks just like the ATF4 which I added to the tranny. It was down about 1/4 of a quart. Thanks for the help.
fpr01
13
09-21-2008 11:31 AM
jrogers
08-17-2006 01:47 PM
ezdemon72
14
07-29-2005 10:05 AM
cjthor
05-10-2005 08:39 AM
Quick Reply: 06 manual transmission leak
