-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   05 tranny flash (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/05-tranny-flash-205317/)
jpsawyer May 19, 2008 08:39 AM
05 tranny flash
The dealer did the tranny flash to lock-out overdrive but it is still going into over-drive. Did i miss something?
jpsawyer May 19, 2008 09:03 AM
I just got off the phone with the dealer & he said the flash is supposed to lock 4th out. I asked if they could do the flash so the tranny will do what the TSB said & he said that is the latest flash and they could not do anything about it. *** over
bob4x4 May 19, 2008 10:22 AM
Doing the flash allows the option of making the tow/haul switch into a od on/off switch.It must still be enabled with the drb after the flash.take it back to the dealer,they need to make it work.
Bob
jpsawyer May 19, 2008 11:40 AM
the dealer told me it is what it is. I am going don south the 30th. I will find a dealer in the Ft. Stewart GA area.
BigIron70 May 20, 2008 12:06 AM
FLash
JP, Here's the TSB so you can take with you to dealer. Don't let them give you any BS[coffee]
jpsawyer May 20, 2008 06:05 AM
Thanks for the info. Now i can get somewhere.
Deaver May 25, 2008 01:17 PM
Related Question
What are the advantages of having this TSB Installed
TonyB May 25, 2008 02:03 PM
Locking out 4th gear....helpful when towing up long hills by not allowing the trans to shift int and out of 4th gear.
Tony
newbie May 25, 2008 05:10 PM
This might be a dumb question but here we go. . . I have a 04.5 srw and I tow a 14k goose. I like the concept of the O/D lock out but if I am towing on flat land and the trans is not searching between 3rd and 4th is it ok to switch to non-tow/haul mode? In tow/haul doing 65 mph I am turning 2400 rpm. TIA!
no_6_oh_no May 25, 2008 10:48 PM
On your truck TH is OD lockout. If it will pull OK leave it in OD and save the fuel.
If it starts hunting and shifting then use TH, or, buy a Smarty and it will almost never downshift. :D
newbie May 25, 2008 10:56 PM
Thanks for the response! Sorry for the hijack.
Plans are in the mix for something along those lines :cool: Smarty or Edge w/ Attitude
