05 ctd running away
APPS could also be an issues. Have you checked for codes yet?
Resetting the APPS.
Turn the key to on, press accelerator pedal to the floor 3 times in a row very smoothly. Turn key off.
I think this is correct from what I remember. A return flow test can be done by the dealers scan tool.
APPS Reset Procedure
This procedure has shown to help 24 valve ISB engines. It is basically teaching the fly by wire accelerator on these trucks to reread the position of the pedal and it's limits. Most complaints this will help with is poor acceleration, improper shifting, bucking in 5 and 6 speeds. Has been known to increase fuel mileage in some instances.
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
I saved that for my 2 01 3500's.Should be the same for 3rd gens equipped with an apps.
If the idle is hanging high I would suspect an injector issue.
norbergauto
Sep 17, 2008 12:44 AM
