05 CTD Rough Idle
I occasionally get a rough idle and the engine doesn't feel near as smooth. It's very random and only lasts for a drive or two even. I shut it off and sometimes it will stay for another drive. Most of the time it's gone.
Really weird. The dealer said they can;t do anything unless they see it acting up. So far no codes no CEL nothing.... What's the deal? Anyone have similar issues? I run powerservice/mmo every other tank sometimes every tank, sometimes every 3rd tank.) The mechanic there said that's ok and sees nothing wrong with that stuff. I tried a couple other products also. Stanadyne and one other. But no changes really. Just odd.. |
I know exacty what you are talking about. Sometimes the engine just seems to run a lot smoother, and sometimes it shakes more than I think it should.
Mine does the same thing, it did it before I started mod's and it does it to this day. I must say it really gets old quick, and I have no clue when its going to start, or stop idleing like sh*t.
I have had the same problem. Kind of a lite missfire. Comes and goes with no rithym to it. Have'nt been able to pinpoint it yet. Could be carbon build up on an injector, fuel, temp, lifter or a valve. It runs fine off idle with no added smoke so I don't think its in the valvetrain.
Mine does the same. But doesn't stay around long enough for me to worry about it:cool:
Michael |
sounds like carbon'd up injectors.
change the fuel filter, fill the filter canister with seafoam, prime the system run the truck for 5 seconds, let it sit overnight. then with 1/4 tank of fuel add 1 bottle of howes meaner cleaner and either pull something heavy or drive it like its stolen. |
A good cleaner
I agree with Redspider.
Even just a can of SeaFoam in a half tank of fuel may be enough to do the trick. I don't tow or work my truck like it should be worked so I like to use some SeaFoam every few months just for preventive maintenance. Only got 31,000 mi on mine but so far no problems with running rough. |
Originally Posted by redspider
(Post 1211575)
change the fuel filter, fill the filter canister with seafoam, prime the system run the truck for 5 seconds, let it sit overnight. then with 1/4 tank of fuel add 1 bottle of howes meaner cleaner and either pull something heavy or drive it like its stolen. Michael |
