03 and 04 Auto-Tran
This is a post I saw on another site and surprised no one here has heard of this, kind of made me wonder if there really is anything to it. Just passing it onto y'all. Here it is:
__________________________________________________ Just saw this on Woodalls and thought would pass it on here. Quote from Reuter's article #6105326 ============================================ Vehicles affected by the possible defect are 2003 and 2004 model-year Dodge Ram 2500 and Dodge Ram 3500 pickup trucks with automatic transmissions, NHTSA said. The agency said 42 crashes and three injuries have been linked to the problem and consumers had made a total of 50 complaints about it. The vehicle might roll backward when the driver attempts to shift the gear into the "park" position with the key still in the ignition and the engine running, NHTSA said. ==================================== |
Never heard of that, and besides you have to have your foot on the brakes to shift to and from park:cool:
Mine had the deadly defect of not stopping for red lights until I started using the brake peddle. I suspect the same method might prevent movement when moving the shift lever to park. I always set my parking brake before putting the lever in park anyhow to prevent "hanging" on the pawl gear.
I've heard about it too. There's a post in the General forum
Here's link to the NHTSA site with the details. http://www-odi.nhtsa.dot.gov/cars/pr...fectsearch.cfm You have to enter action number PE04039 If you read all 20 documents carefully you find NHTSA is also interested in neutral/start switch issues and this includes the failure to shift out of park when the brake pedal is pressed. Some trucks apparently are giving "false Park" conditions to vehicle electronics. Owners who experience either of the issues listed are asked to open a complaint with NHTSA. You can do that from their web page. Nat |
My truck does this, when it is placed in park it seams that there is a spot that it likes to go into that is between Reverse and Park the park light indicator on the dash comes on. It will roll if the parking brake is not set and can be bumped into reverse without the depression of the brake.
Just had my flash for mileage/trip computer and they took a look at the "not going into park" issue as well. Invoice says, "Plastic sleeve not secured to linkage, adjusted linkage, pushed plastic sleeve securely into place." Knida worked, maybe I'm just pushing harder to get it into park.
| All times are GMT -5. The time now is 07:59 AM. |
