'03-'04.5 valve seats
Old Mar 29, 2009 | 10:32 AM
440727's Avatar
Hi, I am looking into a early 3rd generation cummins. Are the valve seats weaker or a problem on the '03-'04.5 Cummins ?
Old Mar 29, 2009 | 10:39 AM
rich's Avatar
kinda a common problem on some dropped them on my 03 and 07 happens with high egt's
Old Mar 29, 2009 | 12:07 PM
1985cucv's Avatar
yeah high egts are the problem but the 05's and 06's are affected too
Old Apr 26, 2009 | 10:41 AM
440727's Avatar
Is it something to worry about if it is going to remain stock ?
Old Apr 26, 2009 | 11:33 AM
soulezoo's Avatar
DTR 1st Sergeant
Probably not. It happens with sustained high egts. On the 03-04, above 1450 for any length time. 04.5 and up used a different design and is less affected and therefore that line is much higher.
Every truck will be different so that egt umber is not written is stone. If you remain stock on an 03-04 you will be fine. 04.5 and up can see higher temps even stock, but should not be a problem either.
92smokin blacky
Nov 6, 2010 10:17 PM
williamdr
13
Oct 20, 2007 09:39 PM
Jeff K
Jan 15, 2007 07:05 PM
judge88
Dec 14, 2006 07:25 PM
Timinva
Dec 31, 2004 02:37 AM
