while the tranny pan is down..
Old Nov 8, 2011 | 09:13 PM
rootkit's Avatar
coming up to 50k on the ticker and going to put new filters in and refill with fresh fluid.
while the pan is out what should i look into at the same time? i was reading something about the bands?
thanks
Old Nov 8, 2011 | 10:15 PM
torquefan's Avatar
Yep, I would adjust the bands for sure. One is done from outside the housing, but the rear band is done from inside.
Old Nov 9, 2011 | 08:04 AM
no_6_oh_no's Avatar
As always, gov pressure transdcuer and solenoid. You are at the replacemnt mileage. Might want to consider an upgraded solenoid at this time also.
Old Nov 9, 2011 | 10:15 AM
Lost Lake's Avatar
Solenoid and sensor for sure. Adjust bands. And it's an awesome time to put in a Transgo kit or a new valve body.
The VB will make your trans shift better and last longer. It costs some money though, but kind of the pay me now or pay me later thing....
Old Nov 9, 2011 | 10:37 AM
NavyDood's Avatar
170,600 miles and never have touched my bands. Every 30-40K I drop the pan, change the filter and replenish the drained fluid. Shifts/operates like the day I bought it 6+ years ago. Towed 20K combined with the Smarty Jr on the 40 hp tune close to 2000 miles a couple of months ago also.
Old Nov 9, 2011 | 11:34 AM
surfram's Avatar
125,000 miles with no band adjustments. I did replace the governor pressure sensor and governor pressure solenoid at 115,000 while doing a trans service.
Old Nov 9, 2011 | 04:41 PM
Lost Lake's Avatar
Yeah, well I ate the front band right down to the steel.... You guys must not tow hard enough or drag race...
Old Nov 9, 2011 | 07:12 PM
92'1stGen's Avatar
"If it ain't broke don't fix it." If it's running fine now, why screw it up. Change the filter, refill the pan, and then tighten it back up.
Old Nov 9, 2011 | 07:32 PM
no_6_oh_no's Avatar
Cuz it will be broke and usually at a very inopportune time. There is a reason Dodge reccommends checking band adjustment every 30k, the stupid bands wear FAST when they get loose. It is not a matter of IF it is a matter of when.
Disturbing the fluid is a good way to make the gov solenoid stop working and foul up the pressure transducer readings. Then you have to drop the pan and do it all over again. Be proactive, change them when it is easy.
Old Nov 9, 2011 | 07:42 PM
quadman20's Avatar
Yeh what he said
Old Nov 9, 2011 | 07:49 PM
SlowJeep's Avatar
Am I dumb that I change the fluid and filter every 15,000 miles?
Old Nov 9, 2011 | 09:23 PM
Lost Lake's Avatar
Well slap my azz and call me Sally....
They wear FASTER when they are loose? I adjusted the front one a little loose, figuring it wears itself loose, I didn't want to over tighten it....
Hmmm... Well I only left the bolt 1/8 of a turn looser than spec. Probably didn't make any difference at all...
Old Nov 10, 2011 | 08:57 AM
no_6_oh_no's Avatar
Well, maybe a little ****. It doesn't hurt but it is excessive, about 30k with normal use. 20k if your towing heavy all the time.
LOL, that funny Haven't heard that expression in a while.
Hard to tell. The external adjustment is not the best nor very accurate. A better way is measure the distance between the actuator rod in the front servo and apply lever tip.
The 1-2 shift is intermediate band apply on a spinning drum. If the adjustment is too loose it slips more thna is desirable until it engages. Too tight and it is dragging all the time.
The 2-3 shift is intermediate band release and direct clutch apply.
Band too loose and it release before the direct clutches apply and you cutaway and direct clutch slip on the shift. Band too tight and you get a bind up shift as the direct clutches apply and try to overide the planetary.
Timing of BOTH actions is VERY critical to operation and wear.
Thats is why the flex band is such a POS in a high TQ heavy load scenario. No matter what you do it is a wear item beacause there is no way to make it perfect all the time. A rigid band with more wear material is a better solution as is good clutches, good shift timing, and higher apply pressures.
Old Nov 10, 2011 | 07:30 PM
rootkit's Avatar
Any chance there's a kit with the filters and gasket with Solenoid and such?
I am looking at the Transgo kit now. May have a local trans shop do it... eh.
Old Nov 10, 2011 | 08:20 PM
92'1stGen's Avatar
76k miles, two fluid changes, 1 filter, no bands and still going strong.
