transmission issues AGAIN! - Won't go over 35mph
Old May 12, 2016 | 02:34 AM
T & T's Avatar
Angry transmission issues AGAIN! - Won't go over 35-40 mph
Aloha Ram friends
I had the trans rebuilt about 2 years ago after blowing it up... New bands and solenoids and TC.
Tonight when I hit about 35mph (regardless of the gear, or OD setting), the transmission would feel like it was slipping into neutral and defueling.
at this point the RPM would bounce as the transmission would engage, then disengage (and engine de-fuel), than catch again. About 1-2 times per second. The truck will not go over 40mph. I stomped on the throttle to see if that had any affect and it ended up overheating the trans...
everything runs normal until about 35mph. I tried putting it into each 1st gear, 2nd gear, OD off, and each time it does the same thing.
At first I thought it was the transmission, but starting to think it is a computer or speed sensor issue.
I tried to look it up but was unsuccessful at finding anything like it.
any help so I know what shop to have it towed to...?
Thanks much.
Old May 16, 2016 | 09:59 PM
T & T's Avatar
Ha! I figured it out. It was the transmission output speed sensor. Was causing the engine to de fuel and tranny to spaz out.
Works great now... $22 from the parts store and several hours scrubbing the Internet.
Old May 17, 2016 | 10:54 AM
47Dodge's Avatar
Did you have a check engine light?
47
Old May 18, 2016 | 12:49 AM
T & T's Avatar
That's what was strange about it. No CEL! Otherwise I would have - should have looked there first... Would have saved me a ton of mis-guided research.
Had a code saved P0720 which led me to the sensor. Not sure why it didn't trigger the CEL.
Old May 18, 2016 | 09:43 AM
47Dodge's Avatar
Very interesting! Thanks for the update and info!
47
Steven K
Jun 4, 2009 10:32 AM
dltriolo
28
Mar 12, 2007 06:45 AM
b84u
Feb 20, 2006 01:04 PM
bigfoot
Aug 14, 2004 02:22 PM
stevek
Aug 5, 2004 03:38 AM
