stock 48RE Question
Old 11-07-2006, 10:01 PM
mijpa's Avatar
stock 48RE Question
I just got back from a deer hunting trip alwost up by new mexico. alot of switch back and long grades pulling almost 11k with a stock 2004. Had to pull alot of those long grades in gear 2 with tow haul on doing no more then 45mph.
Will this hurt my tranny in the long? according to the manual i should be able to use that gear to pull but it doesn't say for how long. when pulling in drive with tow haul on it seemed to lug motor.
Old 11-08-2006, 02:00 AM
TexasCTD's Avatar
Im not tranny expert, but im sure you are fine. These 48RE transmissions are tuff, just not very efficient in stock form. They need a much better Torque Converter and Valve body to put the power to the ground.
Old 11-08-2006, 08:44 AM
XLR8R's Avatar
On a stock 48RE try to keep the TC locked so you won't heat the tranny fluid too much and you'll be fine.
Old 11-08-2006, 10:01 AM
mijpa's Avatar
It was locked but i was in gear 2 for along while no more then 45mph.
Old 11-08-2006, 06:03 PM
John DiMartino's Avatar
Thats perfect,as long as its locked up.The trans temps will be fine if its locked and your moving at least 30mph or so.You shouldnt have hurt anything at all.
Old 11-08-2006, 06:24 PM
mijpa's Avatar
GREAT! Thanks guys.
Old 11-08-2006, 07:01 PM
XLR8R's Avatar
You ought to install a tranny fluid temp gauge so you'll never have to wonder.
Old 11-08-2006, 08:50 PM
mijpa's Avatar
Yeah i will get the 3 guages one day when $ will allow that to happen. I sometimes think should i put some cash into tranny work or get the newer ram with the aisen 6 speed?
Old 11-09-2006, 12:29 AM
TexasCTD's Avatar
..................I sometimes think should i put some cash into tranny work or get the newer ram with the aisen 6 speed?
That is an excellent idea. If you have the spare funds and don't plan any big power modifications an aftermarket Torque Converter and Valve Body will help put the power to the ground. I would suggest you contact DTT or Goerends about those.
Old 11-09-2006, 06:23 AM
mijpa's Avatar
Any idea on a ball park cost?
Old 11-09-2006, 06:40 AM
Rodgeo's Avatar
How do we contact DTT and what is there full name
Old 11-09-2006, 08:30 AM
bluebull's Avatar
www.gbtransmissions.com click on link.
As long as the RPM's are above 1600 your o.k.
Old 11-09-2006, 02:42 PM
raychem's Avatar
Diesel Transmission Technologies, there # is 1-866-504-4002
Old 11-09-2006, 03:20 PM
Big Nate's Avatar
Your converter locks in second when the shifter is in that position? That is a good idea but I don't think mine locks in second and would like it to.
Does anybody have manual control over their converter locking?
Old 11-09-2006, 03:31 PM
tauberson's Avatar
I have really never thought about it before but how to you make the converter lock up. Can anyone shed some light on this for me. I know the 06's are a little diff in regards to Tow/Haul and OD/Off , but how do i make the coverter lock?
Quick Reply: stock 48RE Question
