Removing Oil Filter - Not Full of Oil ???
Old 10-02-2011, 01:32 PM
2005Turbo's Avatar
I have a 2005 Dodge 3500. I was changing the oil today, removed the Fleetguard LF16035 filter expecting the usual oil mess, I was surprised to find the filter was less than half full of used oil. This may be the first time I have used the StrataPore filter. No oil leaks, the engine does not use any oil. Anyone know what is going on?
Old 10-02-2011, 01:40 PM
Hvytrkmech's Avatar
Absolutely normal, oil returning to the sump after shut downs draws down the filter. Your good to go.
Old 10-02-2011, 03:51 PM
PoorMansCat's Avatar
x2... not an issue unless you enjoy oil running down your arm...
As a side note, the old plastic bag trick is by far the easiest way to not get oil on you when changing the filter...
Old 10-02-2011, 03:53 PM
2005Turbo's Avatar
Thanks for the info! I wish it would do that every time. Makes for a lot less mess. Thanks again for hanging out here on Sunday to help folks out!!!
Old 10-02-2011, 08:15 PM
AH64ID's Avatar
Let it sit overnight and it will happen every time.
Old 10-02-2011, 09:58 PM
rockcrawler304's Avatar
True.
I try to get mine up to normal temp and then shut it down and let it sit for about 20 to 30 minutes and the filter is down about 1 inch and never a mess.
Old 10-02-2011, 10:40 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Yeah try doing that when you have 10 people waiting for their oil change to be done in 30 minutes or less. welcome to the real world.
Old 10-02-2011, 11:13 PM
Been there and done that!
redlineguy
15
01-09-2012 09:15 PM
13bdarren
01-27-2009 12:39 PM
West Coast
07-04-2007 10:25 AM
j
11-14-2003 09:38 PM
Quick Reply: Removing Oil Filter - Not Full of Oil ???
