not shifting out of first gear w/o letting off pedal
Old 06-12-2013, 11:48 AM
whyryguy's Avatar
im at a loss guys, my truck had problems shifting in to the first three gears, i had to let off the pedal to get it to shift. i replaced the governor pressure sensor and transduser, filter. when i dropped the pan i found a chunk of the overdrive snap ring. i pulled the overdrive and found the overdrive direct wave snapring in pieces. replaced it and changed the bearings put all back together. refilled with fluid and test drove yesterday. now first gear wont shift with out letting off the pedal. the others gears seem to shift fine. just first gear.
any help would be appreciated i need my truck.
Old 06-12-2013, 11:50 AM
whyryguy's Avatar
sorry i left out my truck info: 2005 2500 5.9 diesel, 48re tranny
Old 06-12-2013, 11:59 AM
j-fox's Avatar
Are you sure the speed sensor is plugged in?
Old 06-12-2013, 12:06 PM
whyryguy's Avatar
Yea just checked.
Old 06-12-2013, 03:01 PM
whyryguy's Avatar
ok i drove the dodge again and it seems that, it wont shift if im into it a bit (doesnt have to be much) but if im putsin along (not much more than idle) it will shift from first gear as its supposed to.
speed sensor is clean.
should i check the bands?
any other ideas?
Old 06-17-2013, 03:15 PM
Super Googan's Avatar
My truck did that when I adjusted the front ( kick down ) band and had it a hair too tight. 1/4-1/2 turn looser fixed my issue.
Old 06-17-2013, 04:48 PM
whyryguy's Avatar
Thanks for the reply, I attempted to adjust my front band. It was super loose... I could have screwed it all the way in by hand no problem. I couldnt feel any resistance at all. Is that norm or do you suspect internal issues with the band?
patg
09-23-2010 12:30 AM
Tractor Truck
08-23-2010 11:27 PM
the.hogman
02-18-2010 10:56 AM
DodgenIt
02-20-2008 01:59 AM
Viesel
21
02-09-2007 08:14 AM
Quick Reply: not shifting out of first gear w/o letting off pedal
