Coolant Leak!!! HELP!
Clearly from the pics you posted you have a head coolant plug leak. The real question is why? If you notice the black staining on the #6 exaust manifold, this would give me more pause for concern coupled with the head plug leak. I think your problems are deeper than you think.
I tightened up those plugs. There is a small amount of black staining where the manifold bolts on @ #6. I did notice that the plug closest to the back of the exhaust manifold was a little loose. I cleaned it all up and I'm going to run it this morning and see what happens. Would the coolant leaking out of that plug cause that small part of the manifold to turn black? Could the fact that the Crankcase vent needing to be replaced play any part in the coolant showing up?
My concern is that the #6 cyl has been overheated which in turn weakens the thread seal on the coolant plugs. I think the coolant leaking rearward onto the exhaust manifold may have exasperated the appearance of the soot or oil staining in the picture. I would pull an oil sample and send it out for analysis.
Aside from the obvious leak, the green coolant is a red flag to me the truck's cooling system has had some attention. Coolant is suppose to be HOAT, not the typical EthGlycol. The suspicion that someone who didn't know what the truck spec'd was working on it makes me nervous.
I can't speak for the rest but look like Hvytrkmech has got you covered on that. He knows his stuff.
Wash down that block so you can get a clear view of what's going on. You know you have a problem, start pinpointing.
To touch on what Shorts commented on, could the fact that the wrong coolant was in the truck caused the #6 cylinder to overheat?
@Shorts I did have someone change my fan clutch as well as pull the radiator so I could have it fixed. He was the guy who put the green coolant in. I already went and picked up some HOAT "red" coolant from the dealer and will be flushing the system as soon as I finish installing my Spyntec free spin hubs.
cutthroatxxx
17
05-22-2015 07:09 AM
george7941
11-28-2009 09:28 PM
Mark Hodowanec
08-17-2009 11:56 AM
