Black soot through exhaust and on bumper
Old 12-21-2007, 08:42 AM
06RAMCTD's Avatar
I don't really notice it too much during the day but, at night I can darken the cars behind me with anything more than 1/2 throttle. Also, the bumper and rear panel constantly get heavy soot build-ups over a months period. This condition has been present since day 1 of ownership.
Is this normal?
Is the engine running rich?
Is this indicitave of any other issue(s)?
The truck is stock and as indicated in the signature line.
Thanks for the input!
Old 12-21-2007, 09:15 AM
JCLeary's Avatar
Yes, it's normal.
No, your engine is not running rich. Diesels are "lean-burn" engines and consume all the air they need. There is no throttle valve like a gasser (at least on the 5.9's)
It's an indicator of having a catalytic converter. Your converter plugs with soot, and when you get on it the soot is blown out. It will deposit on your bumper.
Enjoy your diesel! All normal! If you see white smoke (not steam/condensation, but heavy, white smoke) at startup you may have a problem. Also, if you have heavy black smoke accompanied by knocking, you may have a problem. Other than that, a little soot is all good!
Old 12-21-2007, 09:50 AM
Danavilla's Avatar
My '06 produces little smoke, even with 11K RV pulling hills. I have a chrome exhaust extension but don't believe it extends much beyond the original. There is very little soot of the front of the RV after even several thousand mile trips and it's only a few feet from the tailpipe outlet. There's virtually none on the truck.
I do try to keep exhaust temps down so that may be why, I don't know.
My truck is also totally stock, performance wise.
Dan
Old 12-21-2007, 11:00 AM
donnee's Avatar
I had a certain amount of soot build up on mine and cured it with a turndown tip from Geno's.
Old 12-21-2007, 01:10 PM
D-Roc's Avatar
What is the sound like with a turndown tip?
Old 12-22-2007, 09:52 AM
donnee's Avatar
I dont think it sounds bad at all.
I did the turndown when I put the MBRP muffler on.
Old 12-22-2007, 09:58 AM
t-boe's Avatar
This is what I did to keep soot off my truck. A few others have done the same thing. Eddie Reyes was the guy that gave me the idea.
[IMG][/IMG]
[IMG][/IMG]
Old 12-22-2007, 10:13 AM
preloader's Avatar
[/IMG]
Or you could do this
Old 12-22-2007, 11:49 AM
surfram's Avatar
My turndown eliminated this problem and it bounces the exhaust sound off of the ground. Turndowns will leave dead spots in your yard if your leave your truck idling with the tip over the grass.
Old 12-22-2007, 12:13 PM
Hintz's Avatar
[IMG][/IMG]
[IMG][/IMG]
did you rebend the pipe or get an exhaust shop to bend you up a pipe for it? I like that way a lot
Old 12-22-2007, 12:15 PM
t-boe's Avatar
Just cut above the bend and clock the pipe towards the rear. Using a 24" long tip helps too.
[IMG][/IMG]
Old 12-22-2007, 04:08 PM
rustyshakelford's Avatar
wash your truck more than once a month
brett
Old 12-22-2007, 07:50 PM
DiEseLjunKy's Avatar
Turndown? I think the black bumper looks
Old 12-23-2007, 09:14 AM
buddy26's Avatar
When I tow, I return my trucks to stock and never have any soot build up. Only when I have my BDDL downloaded do I get soot.
06RAMCTD
13
08-29-2012 03:54 PM
CTD8939
18
11-21-2007 05:53 PM
Schmed
29
06-10-2005 12:34 AM
EKUgrad
05-15-2005 06:08 AM
Huntindad
04-19-2004 02:21 PM
Quick Reply: Black soot through exhaust and on bumper
