axle seals and ball joints
My front passenger side axle seal is leaking pretty good now. I figure if I have to pull the front end apart I might as well do the ball joints so I don't have to dig into it again for a while. Does anyone know who has dynatrac or carli ball joints in stock for an '05 4wd?
go straight to the source both dyna track and carli sell direct. bummer about the axle seals not that many problems with them yet. the seal actually grips the axle shaft and has a bushing where the seal rotates inside itself if that makes sense. they are a pita to install though gotta pull the diff all out and drive em in from inside diff housing. i would also do axle u joints so you don't have to pull axle shafts out later as re-installing them is when most seals get chundered.
firebill1720
20
03-05-2010 09:23 AM
Wulzcat
12-22-2009 02:28 PM
Wulzcat
12-19-2009 05:15 PM
