Atf + 4
Old 02-07-2014, 08:30 PM
Fiftygrit's Avatar
Atf + 4
Where is the cheapest place to get 2 cases of atf+4 I have a double deep trany pan and a complete change takes around 21 to 22 quarts, have been using Valvoline as it is synthetic, Im down in Arizona till the end of March, thanks, cheer`s
Old 02-07-2014, 11:02 PM
lovinCTD59's Avatar
Supertech from Walmart will be the cheapest from what I have seen.. have you thought about trying Amsoil Synthetic ATF? Its good stuff, can go 3x the normal change interval unless its overheated.
Old 02-07-2014, 11:44 PM
justen920's Avatar
I use amsoil but 5.5 gallons would put a big dent in the bank account.
Old 02-08-2014, 11:23 AM
Fiftygrit's Avatar
Ya I have used Amsoil, way too much money even with the preferred customer and dealer rates, thanks
Old 02-08-2014, 11:45 AM
Dodgetracker's Avatar
The Valvoline has excellent properties, I didn't do much research on Supertech stuff but supposedly it's all the same if it is +4 ATF. Did a lot of reading about oils and such over the holidays.
Old 02-08-2014, 12:50 PM
pronstar's Avatar
Check Amazon, sometimes they have great pricing. I picked up two cases of Valvoline ATF for under $4/bottle, free Prime shipping.
It's hit and miss, but there are good deals if you check regularly.
Old 02-08-2014, 05:50 PM
Rob's Red Ram's Avatar
google up atf+4 and read.it's basically all the same as Chrysler has to give them the license to make it .And yes wallymart supertech is cheap and will do the job fine.
Old 02-09-2014, 05:05 PM
Dr.Dizzle's Avatar
Advance Auto Parts currently has all Castrol ATF's on sale, including ATF+4 for 4 dollars per quart. Order it online and pickup in store.
https://shop.advanceautoparts.com/wc...2014-flexi.pdf
Pig
23
06-04-2010 01:01 PM
Mslaughter
08-24-2006 06:44 PM
dieselfan
08-05-2006 10:44 PM
Pig
03-13-2006 09:12 PM
98rammer
11-04-2002 06:23 AM
Quick Reply: Atf + 4
