Why do I have no wait to start light?
i have a 95 3500 2wd regular cab and its not a stripper model or anything. So do any of you have any idea why I dont' have a wait to start light?
I thought it was maybe because the light bulb was broken or something, but when i took the dash apart, there was no bulb or anything there. Were there some models that didn't have the light at all, or did the previous owner probably jack around with it. Any suggestions on how to go about getting one back? Can I rewire it in or something? Thanks for the help! |
The light doesn't go on unless the temp is below 50°
well thats good to know. :D
but you missed what i was saying. I took apart the dash, and there was nothing there...the little cutout that says "wait to start" is there..but no bulb or harness or wiring behind it at all.... :confused: :confused: :confused: :confused: edit: by the way....how did you do the actual degree symbol? ascii? |
ALT + 0176 = °
Or you can always use the "character map" Tony ps - don't know about your "wait to start" lamp missing?! |
I see you aren't the original owner.
Perhaps it came from a warm climate where the WTS wasn't needed, so the previous owner just ripped it out? Are your grid heaters still intact? Perhaps they were ripped out after they stopped working right? so they removed the useless light along with them? phox |
Or it was a V-10 that someone slipped a Cummins in to.
Look and see if you have two large cables going to the grid heaters on top of the manifold. |
Isn't the "wts" light in the 95 at the bottom of the HVAC control along side the trans temp light?
ok...some answers here.
the truck was from central illinois originally..so that prolly isn't it... I have no idea about the grid heaters. but i shall follow the cables. The truck was deffinately a diesel to begin with..its sitting at a shop right now for four (4) recalls that never got fixed on it. and yes...the light is supposed to be under the hvac stuff, and there is another spot for a light there, but i don't know what it is for. So ultimately what I'm getting from you guys, is that yes, something was supposed to be there, but somebody screwed around with it and its now gone, right? A friend of mine is the dodge diesel tech at the dealer here, so i will check with him to see if he can hook me up with another one. :) Thanks guys! |
Why worry about the light. You can hear it click when the grids go off anyway.
Or watch the voltmeter
Originally posted by pogorules Why worry about the light. You can hear it click when the grids go off anyway. Originally posted by infidel Or watch the voltmeter and besides, like many other simple minded folk, i am mesmerized by lights and pretty colors. :D Thanks for the info guys!:cool: |
Since your grid system does appear to be working it makes me wonder if you somehow got the dash wiring for a gasser. I can't imagine anyone purposely removing the lighting. If you do indeed have the gasser wiring the dash will have a light that indicates when to shift gears, indicated by a upward pointing arrow.
nope...no shift light....quite perplexing, eh? lol
maybe ill pull the dash apart again and check to see if it is hanging around behind the radio or something...maybe it broke and fell, and is just hiding behind something obscure... |
Maybe someone replaced the dash or ? due to an accident or ? just my .002
º Symbol...
Originally posted by riffman ...how did you do the actual degree symbol? ascii? |
