wheel cleaner product for 2nd Gen factory alloy wheels
Old Jan 20, 2012 | 06:26 PM
royta's Avatar
I have two sets of 2nd Gen factory 16"x8" alloy wheels that I want to clean inside and out. The plan is to clean all the wheels absolutely spotless and choose the best four to have a new set of tires installed on. The other four will be sold. I also have a set of early 2nd Gen 16"x6.5" chrome steel wheels that I need to do the same with for a possible set of winter tires.
What easy to find wheel cleaning product is suggested for the clear coated alloy wheels? What about for the chrome steel wheels? I need to be able to buy the product at O'Reilly, Autozone, or Pep Boys. I know Eagle One makes wheel cleaning products, but I don't want one that is so strong that it ruins the clear coat (or attacks at the chips in the clearcoat), and also not so weak that I need to scrub for hours. There is a large amount of brake dust on the inside exterior of the wheels that needs to be removed.
What have you folks had good results with?
Thanks.
Roy
Old Jan 21, 2012 | 12:06 PM
SIXSLUG's Avatar
Soap and water is really all you need. I used a stiff and soft bristled brush on mine and they cleaned up pretty good.
If you are really concerned about the appearance, have the tire guys use stick on weights, as the crimp on types will ruin the clear coat and cause the wheel to corrode underneath.
Factory stock, OEM, brake pads will give the least dust, also.
Old Jan 22, 2012 | 09:46 AM
royta's Avatar
The outside exterior of the wheels (away from brakes) are already nice and clean. I'm trying to remove the buildup of the inside exterior (the brake side). Soap and water and a soft bristle brush don't even begin to cut through it.
Sent from my DROID X2 using Tapatalk
Old Jan 22, 2012 | 11:44 AM
SIXSLUG's Avatar
You need a grease cutter like castrol super clean and a stiff brush for the backs. They pick up a lot of road grime since they aren't polished. You won't get them super clean though, they pick up a brown/purple stain from the brake dust.
You would probably need a wire wheel to get that off.
Old Jan 22, 2012 | 02:28 PM
Dave2001's Avatar
Believe it or not, I use Go Jo hand cleaner. I also use this on my chrome tip.
Old Jan 22, 2012 | 11:16 PM
SIXSLUG's Avatar
That's a great idea. I have used it on my work clothes to get grease out for years!!
esorensen
Nov 14, 2012 09:44 PM
royta
Feb 12, 2012 12:32 PM
stock03
Apr 22, 2011 09:52 PM
Diesel97
Apr 29, 2007 12:42 AM
00turbo
Oct 7, 2004 12:36 PM
