Wheel Bearing
Just wondering if the wheel could fall off it the wheel bearing is shot??? All i have to do is load it on the trailer and unload it. I dont want to get it half on the trailer and have it fall off. Also is there a good place to pick up a set of wheel bearings??
Thanks Devin |
if you have a 2 wd timken set# 814 will do you
Its a 4x4.
I found them for my 98 in the back of diesel power magine. It was the ad for JT's differential. They were $275 plus shipping apiece. This was cheaper than anywhere else I could find. I also read on here somewhere that at RockAuto.com had them for $175 but i don't know that for sure. Tim
Originally Posted by ILLINOISRAM
(Post 1986538)
Rockauto.com sells the Timken sets. Very cheap.
Originally Posted by scottsjeeprolet
(Post 1988694)
Here is the info i pulled up. 1999 DODGE RAM 2500 PICKUP 5.9L 359cid L6 DIESEL FI Turbo (6) : Brake/Wheel Hub : Wheel Bearing Print Save My Place Related Parts Item Price Core Total Advice TIMKEN Part # 15245 Cup; Front Whl,Outer,2WD; 4000 lb. Axle;8 Stud $3.00 $0.00 $3.00 Add to Cart BCA/NATIONAL Part # 15245 More Info {Taper Bearing Cup Outer Diameter=2.441" Length=0.5625" Radius=0.046"} Front Wheel; (RWD); Outer; Tapered Cup Part Image $3.81 $0.00 $3.81 Add to Cart TIMKEN Part # JLM506810 Cup; Rear Whl,Outer; Spicer 80;13x3.5" Brk. $6.96 $0.00 $6.96 Add to Cart TIMKEN Part # 15101 Cone; Front Whl,Outer,2WD; 4000 lb. Axle;8 Stud $7.32 $0.00 $7.32 Add to Cart TIMKEN Part # 28622 Cup; Rear Whl,Inner; Spicer 60 Axle;13x2.5" Brks. $8.84 $0.00 $8.84 Add to Cart TIMKEN Part # 39520 Cup; Rear Whl,Inner; Spicer 80;13x3.5" Brk. $8.90 $0.00 $8.90 Add to Cart TIMKEN Part # SET45 Set; Front Whl,Inner,2WD; 4000 lb. Axle;8 Stud $9.34 $0.00 $9.34 Add to Cart BCA/NATIONAL Part # JLM506810 More Info {Taper Bearing Cup Outer Diameter=3.5433" Length=0.7283" Radius=0.02"} Rear Wheel; Outer; Tapered Cup; (Spicer 80) (13 x 3.5" Brakes) Part Image $9.37 $0.00 $9.37 Add to Cart BCA/NATIONAL Part # 15101 More Info {Taper Bearing Cone Bore=1" Length=0.8125" Radius=0.031"} Front Wheel; (RWD); Outer; Tapered Cone Part Image $9.71 $0.00 $9.71 Add to Cart TIMKEN Part # 6408 Bearing; Rear Wheel; 9.25" R.G.;Exc. H/D Axle $10.18 $0.00 $10.18 Add to Cart TIMKEN Part # SET38 Set; Rear Whl,Outer; Spicer 60 Axle;13x2.5" Brks. $10.36 $0.00 $10.36 Add to Cart TIMKEN Part # JLM506849 Cone; Rear Whl,Outer; Spicer 80;13x3.5" Brk. Choose: Add to Cart BCA/NATIONAL Part # A35 More Info {Cone Length=0.58" Bore=1.625" Outer Diameter=2.891" Width=0.77 Stand Out=0.19" Cup Length=0.58" Cone Radius=1.14"} Front Wheel; (RWD); Inner Part Image $10.87 $0.00 $10.87 Add to Cart BCA/NATIONAL Part # 28622 More Info {Taper Bearing Cup Outer Diameter=3.8437" Length=0.7656" Radius=0.031"} Rear Wheel; Inner; Tapered Cup; (Spicer 60) (Spicer 70U) (13 x 2.5" Brakes) Part Image $11.51 $0.00 $11.51 Add to Cart BCA/NATIONAL Part # 39520 More Info {Taper Bearing Cup Outer Diameter=4.4375" Length=0.9375" Radius=0.125"} Rear Wheel; Inner; Tapered Cup; (Spicer 80) (13 x 3.5" Brakes) Part Image $11.58 $0.00 $11.58 Add to Cart BCA/NATIONAL Part # A38 More Info {Cone Length=0.65" Bore=2" Outer Diameter=3.25" Width=0.85 Stand Out=0.2" Cup Length=0.65" Cone Radius=1.14"} Rear Wheel; Outer; (Spicer 60) (Spicer 70U) (13 x 2.5" Brakes) Part Image $12.78 $0.00 $12.78 Add to Cart BCA/NATIONAL Part # 6408 More Info {Cylindrical Bearing} Rear Wheel; (9.25" R.G.) (Exc. H/D Axle) Part Image $13.73 $0.00 $13.73 Add to Cart TIMKEN Part # 28682 Cone; Rear Whl,Inner; Spicer 60 Axle;13x2.5" Brks. $15.60 $0.00 $15.60 Add to Cart BCA/NATIONAL Part # JLM506849 More Info {Taper Bearing Cone Bore=2.1654" Length=0.9055" Radius=0.06"} Rear Wheel; Outer; Tapered Cone; (Spicer 80) (13 x 3.5" Brakes) Part Image $19.07 $0.00 $19.07 Add to Cart BCA/NATIONAL Part # 28682 More Info {Taper Bearing Cone Bore=2.25" Length=0.9688" Radius=0.14"} Rear Wheel; Inner; Tapered Cone; (Spicer 60) (Spicer 70U) (13 x 2.5" Brakes) Part Image $20.79 $0.00 $20.79 Add to Cart TIMKEN Part # 39585 Cone; Rear Whl,Inner; Spicer 80;13x3.5" Brk. $24.79 $0.00 $24.79 Add to Cart TIMKEN Part # R1561TV Bearing; Rear Wheel; 9.25" R.G.;H/D Axle $28.89 $0.00 $28.89 Add to Cart BCA/NATIONAL Part # 39585 More Info {Taper Bearing Cone Bore=2.5" Length=1.1875" Radius=0.14"} Rear Wheel; Inner; Tapered Cone; (Spicer 80) (13 x 3.5" Brakes) Part Image $32.79 $0.00 $32.79 Add to Cart BCA/NATIONAL Part # R1561TV {Cylindrical Bearing} Rear Wheel; (9.25" R.G.) (H/D Axle) $38.89 $0.00 $38.89 Add to Cart ACDELCO Part # LM102949 {#09440844} BEARING,RR WHL OTR 7.75" RING GEAR-CONE-NEW PROCESS 4500-5 SPEED * Non-stock item--shipping delayed up to 12 business days $23.99 $0.00 $23.99 Add to Cart ACDELCO Part # 387A {#09441046} CONE,RR WHL BRG INR CONE * Non-stock item--shipping delayed up to 12 business days $33.89 $0.00 $33.89 Add to Cart I can't find it anywhere on there website. |
I'll give you my hub/bearing assembly from my 99. I replaced it thinking it was bad but it was actually the control arm bushings. Just pay for shipping which I think is about $30 because it's heavy. Tired of triping over it in the garage.
That's because you needed to click on Axel bearing hub assy, not wheel bearing.
TIMKEN Part # HA590018 Hub Unit Bearing; Front Whl,2WD; Solid Frt. Axle;DRW;Non-ABS Hub Unit Bearing; Front Whl,4WD/AWD; DRW;Non-ABS $132.79 $0.00 $132.79 Add to Cart BCA/NATIONAL Part # 515070 Front Wheel; Hub Assembly; (Dual Rear Wheel) (Rear Wheel ABS) $187.89 $0.00 $187.89 Add to Cart TIMKEN Part # SP580102 Hub Unit Bearing; Front Whl,RH,4WD/AWD; DRW;ABS; 8 Stud, New Item. $192.79 $0.00 $192.79 Add to Cart TIMKEN Part # SP580103 Hub Unit Bearing; Front Whl,LH,4WD/AWD; DRW;ABS; 8 Stud, New Item. $192.79 $0.00 $192.79 Add to Cart BCA/NATIONAL Part # 515069 Front Wheel; (4WD); Right; Hub Assembly; (Dual Rear Wheel) (4 Wheel ABS) $272.79 $0.00 $272.79 Add to Cart BCA/NATIONAL Part # 515068 Front Wheel; (4WD); Left; Hub Assembly; (Dual Rear Wheel) (4 Wheel ABS) $282.79 $0.00 $282.79 Add to Cart |
(Post 1988793)
TIMKEN Part # SP580102 Hub Unit Bearing; Front Whl,RH,4WD/AWD; DRW;ABS; 8 Stud, New Item. $192.79 $0.00 $192.79 Add to Cart TIMKEN Part # SP580103 Hub Unit Bearing; Front Whl,LH,4WD/AWD; DRW;ABS; 8 Stud, New Item. $192.79 $0.00 $192.79 |
well i found out that the wheel can fall off. by the time it was on the trailer the only thing holding the wheel on was the brake caliper. the wheel was at a 45 degree angle. I have never seen a wheel bearing all of a sudden pile up that fast to the point of not being able to limp the truck some were. I had to fix the truck right on the trailer cause it wasnt coming off the trailer without anymore damage. It wasnt to bad it was nice and warm over here for a change and was able to get it done. What has everone else been getting for mileage out of there wheel bearings?????
Thanks Devin |
I was going to reply the wheel will fall off.
It happened to me at 75mph on a passing lane in North Dakota..... Same issue the brake caliper held the wheel in position while truck was "roaming" the median, and I was filling my pants. |
