WATER IN CAB!!!!
I have got water on the floorboard of the passenger side of my truck. Of course, it didn't show up until the rain started. Any ideas??<br><br>Thanks in advance!!!<br><br>
Re:WATER IN CAB!!!!
Cab mounted brakelight gasket is leaking, or A/C drain is plugged up. Check the cab light first easiest to get to and if the foam around the plug is wet you know you have a leak there for sure. These things are bad for leaking!.
Re:WATER IN CAB!!!!
;D If the passenger is a PSD owner it may be them.. The torque and speed is scaring em to death [laugh]
Re:WATER IN CAB!!!!
OK, here's the final outcome. <br><br>Picked up my truck today at 2pm. Here's the work off the dealers work order:<br><br>R&R right side scuff plate, kick panel, carpet and pad, L&R wipers and plenum grill.<br><br>-Sealed plemun seam<br>-Sealed floor seam at fender wall<br>-Sealed A/C drain<br>-Cleaned A/C drain<br>-Dryed carpet<br><br>-Replaced pad<br><br>Work performed by Leak Masters out of Port Orchard and the rental taken care of by Tacoma Dodge. Pretty good warranty service in my opinion.<br><br>This should serve as a warning to all those with '02 trucks I guess. My dad's truck underwent the same treatment and with almost identical results.<br><br>If you have any questions, give me a hollar.<br><br>Later
