Vibration when turning
Old Mar 31, 2007 | 07:01 PM
quarry adams's Avatar
Hey guys, First post. Sweet forum
I get a vibration at highway speeds when turning to the driver.
It only happens when i turn driver. and feels like your driving over the bumps in the breakdown lane.
I think its related to this squeek i have goin on in the driver side wheel, i can only hear it at slow speeds and goes away for a couple seconds if i nail the brake.
Also on that same side i get a knock if in 4wd and taking a slow turn.
I was thinking it was a u joint or upper ball joint but i really dont know.
the vibration isnt always consistant. some times its bad and sometimes not so much and about 3 times its continued to vibe even when i straightened out the wheel, but once i stop and go again it doesnt happen any more.
I know its not the death wobble and the tires are pretty new.
Any insight?
thanks
Old Mar 31, 2007 | 07:09 PM
bigdave's Avatar
sounds like a wheel bearing to me
Old Mar 31, 2007 | 08:53 PM
JKM's Avatar
JKM
Sounds like either a wheel bearing or an axle shaft U joint.
Old Mar 31, 2007 | 09:48 PM
TIMMY22's Avatar
Jack that side up and give it a spin. push/pull top to bottom of tire and push/pull front to back. If you don't see anything out of the ordinary, try the other side. Then get back to us on what you find.
Old Apr 5, 2007 | 03:42 PM
The ball joint on the top is allowing the knuckle to shift from side to side.
I had to get a bar between the tire and the ground and push it up to see any movement.
lookin4cowgirls
13
Jul 23, 2018 02:26 AM
Mopar1973
May 16, 2012 08:04 PM
JARHEAD
Mar 14, 2011 01:20 PM
dodgedsl03
Jan 18, 2007 10:08 PM
