Underhood fuse box.
Old Feb 13, 2009 | 10:02 AM
kc8ksg's Avatar
Question Underhood fuse box.
The terminal that supplies power to my underhood fuse box is loose, I tracked it down after the lights started flickering, and I went to tighten it and whatever is supposed to hold the bolt on the other side feels like it is slipping and the whole thing is turning, I am guessing there is a piece of plastic around the bolt and it is broke or worn out letting it turn. Anyway my question is if I remove the fuse box is what I am guessing correct or can I even get to the other side of the terminal when I get the fuse box out, or is there a way to get to it without removing the fuse box?
Thanks
Chris
Old Feb 13, 2009 | 10:05 AM
infidel's Avatar
Can you hold the threaded part of the bolt with needle nose, etc while tightening the nut?
May make it easier for you.
Old Feb 15, 2009 | 10:31 AM
sheriffav8r's Avatar
I would guess that both terminals are interior to the fuse block. Removing the fuse box should give you some sort of access to the back side. Doesn't sound like a fun job, though....
1999 duallie
Mar 12, 2013 07:05 PM
bigjohn92
Nov 25, 2010 01:32 PM
Evildiesel
Nov 18, 2005 04:12 PM
TDIwyse
Aug 21, 2004 12:24 AM
mazeeff
Jan 24, 2004 10:47 PM
