Oil pressure gauge problem
When I get in my truck and turn the key to the ON position (engine is not running) my oil pressure gauge goes to the top of the operation range and stays there. Once I start the truck it doesnt budge it just stays put until I turn the truck off. I know there are a lot of sending unit issues but from what I understand of the sending unit is bad the gauge would read zero all the time. Any ideas?
Just and FYI for everyone, I talked to my local Cummins shop this morning they they said my problem is most likely the sending unit. They said unlike most sending units the one used on the 24 valve engines can act erratic and swing from 0 to the top of the scale and everywhere in between when they go bad. The ones they are selling are supposed to be a much better unit the only bummer is the plug is different so you have to buy a pigtail and replace the factory plug on the truck. New sending unit $79, pigtail $11.
Replaced mine at 140K miles. It had the same symptoms. It would always indicate the same pressure, even with KOnEOff.
The replacement was a like-for like fit - no adapter. When I get off othe road I can look up the part number for you. In 2001-1/2 they went to a different sending unit which was essentially just a make-or-break style (idiot light) and the computer used an algorythm to generate a pressure signal that would appear correct based on engine speed and temperature. Make sure that is NOT the sending unit the parts guy is trying to sell you!
Dry Creek
Dry Creek
my oil pressure guage is also staying at top of operating range while the key is on, running or not. checked price at napa and they said they could order one for like $190. hope they are cheaper than that from the dealer
GlennRMK
05-24-2007 10:46 PM
streetsmoker
02-22-2006 06:47 PM
callum
11-21-2004 07:04 PM
