Tire/wheel ?, 1st year 235-85-16s were stock on 3500s
I may go to 255-85s on my next set of tires. Since the wheels on the trucks that came stock with 235s have more offset, I'm gonna start shopping for a set. But, due to CRS, can't remember the first year for the greater offset wheels. 2000, 2001 or perhaps 2002?
I'm thinking that with a set of 1/4" spacers these wheels may work with no rubbing.
Anyone?
Thanks, RJR
Anyone?
Thanks, RJR
Muted User
i was told they will fit fine with no spacer and mine is a 01. a friend of mine runs em his ford with now spacer and towes a 24ft trailer with a monster excersion on it and still no rubbing. but then again that is a ford i do not know what the spacing is on that truck.
Thanks for the replys guys. It looks like the key is to have the 8 slot wheels, first used on 2000 year trucks. The 4 slotted wheels are for the 215s like I have.
RJR
RJR
i was going to go with the 255s on my dually but i could only find them in mud tires. i have since went to 285 yokohama's with a 2 inch spacer. i like it a lot and no rubbing on the front.
I have 235/85's on my 98.5 and only had 5/8" clearance between them - not quite enough.......I made up some 3/8" spacers to make it an even 1" clearance and I have no signs of rubbing........as it has already been mentioned 2000 is the 1st year for the 235/85 with the larger offset rim.........you will definately need spacers for your 95 if you want to run 255's.
Dodgezilla
03-23-2007 05:46 PM
Dodgezilla
30
03-17-2007 09:30 AM
