Tire size?
Tire size?
I have a 1994 3500 cab chassis 4x4 with 215/85/16. I went to a dealer and he said I should put on 235/85/16 tires. Can these tires fit the rim and wheel wells? I am worried the duallies will hit each other and also effect turning. Anyone with experience with this situation.
Thanks
Rob
Thanks
Rob
I can assure you that they will fit the wheel wells, as that was the size that came on my 2000 from the factory. Your '94 came with different size wheels though. I do not know for sure if you have enough backspacing for the wider tires, but I would think it should be real close if they do not fit. Maybe someone has a set off one of the new trucks they want to get rid of, if I still had mine, I would offer to sell them.
Checked door and nothing. I think if I had singles it would not be a problem but with dullies it may. I did a tire comparison an tire rack and says the tire will be .79" wider. So will be close. I don't wanna buy tires that won't fit. I will also ask a tire dealer if its possible.
thanks,
Rob
thanks,
Rob
I have a 97 dually and had the same dilema. went to 235/85/16 dunlop a/t with no problem at all even with 8k load the duallies still have good space and 235 are cheaper than 215. Forgot to mention I have 6k on these tires and very happy with them I payed 110 each installed etc.
Check that door jamb again. The sticker should be there.
tirerack.com site might be able to pull it up via your truck info too...or the owners manual if you have it.
you've got the right idea though..duallies need some space between them with full load and air pressure.
schoust
Oct 21, 2009 10:09 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
4RnrRick
Feb 27, 2007 11:25 AM
