Steering wobble/"jerkiness" in slow turns
Old May 6, 2006 | 10:19 AM
DrBob's Avatar
Hello Gentlemen:
'99 24V shortbed stock quad cab a/c auto gvw 8800 194K on it
When I am going slow the steering wheel gets"jerky" when making turns. It comes and goes but is staying a little longer each time. Any ideas? Power steering pump? Steering box?
I'd love your input so I don't spend a fortune with a mechanic that doesn't know how to fix it correctly the first time! Thank you!
Bob
Old May 6, 2006 | 10:21 AM
Front axle u-joints. Check 'em out.
Old May 6, 2006 | 03:46 PM
DrBob's Avatar
But it comes and goes, wouldn't the front axle u-joints make it wobble all the time and even when going straight or hitting bumps? The steering seems a lilte "harder" when it happens too. Sometimes it seems that the problem is reduced after turning the truck off or turning the wheel from R to L and back a few times. Thank you for your repsonses guys. I'll PM you when I get a chance tomorrow Wannadiesel. Again, thanks!
Old May 6, 2006 | 03:49 PM
The U joints are pretty much out of the picture when you are driving straight ahead. That's why it only does it in turns.
Old May 6, 2006 | 04:11 PM
snow ram's Avatar
if its anything like mine, it almost feels like youre in 4WD... i think i have it narrowed down to the pump starting to go south, but i dont have the ambition to replace it
according to mitchell, i have to take my vac. pump off with it, but when i look at it, it looks like i could just undo the lines and then the bolts/studs and slide it off, then bolt the new one back on....i may be wrong
anyone done one around here??
-Josh
Old May 7, 2006 | 10:40 AM
DrBob's Avatar
Yes, that is exactly it! I t feels like you are in 4WD on dry pavement. So far I'll have the guy check the U joints and power steering pump. Please keep the info coming...
Old May 7, 2006 | 10:51 AM
BigDodge's Avatar
Have you tried pulling the filter screen and cleaning? it might be partially plugged.
Steering pump screen
Dave
725Gus
Mar 6, 2014 09:49 AM
pipefitter
Feb 27, 2014 05:11 PM
Maui Steve
Nov 6, 2006 10:45 PM
snowball
Jul 17, 2005 04:09 PM
