Steering Box Rebuild - where can I find parts
Old Jul 31, 2008 | 10:38 AM
bob95065's Avatar
My steering box is sloppy and I want to rebuild it. Where can I find parts?
Old Jul 31, 2008 | 11:16 AM
dozer12216's Avatar
There are some adjustments that might help. They are covered in FSM. Don't believe Dodge has a real overhaul kit. Just a few seals. GM uses same unit and generally avaliable if can convert #'s.
Old Jul 31, 2008 | 11:49 AM
bob95065's Avatar
I adjusted the box and it is still loose. The sector shaft has play when the wheel is turned and the box needs to be rebuilt. Do you know the manufacturer and part # for the box? That may help in buying parts.
Old Jul 31, 2008 | 07:10 PM
9512vCTD's Avatar
im in the same position right now, heres what i foundhttp://www.partsamerica.com/productd...ype=22&PTSet=A
If you look at the picture it shows a couple bearings, im not sure if it is worth a try or not. I just pulled my steering box, and shaft off tonight. Im suspecting them both being worn out..
nbaggett89
Dec 26, 2015 09:36 AM
subspd
May 20, 2007 10:15 PM
CTD_Neil
Jul 19, 2005 08:13 PM
