Slave Cylinder Replaced Now Clutch Squeels
I had the slave cylinder go out a few weeks ago and a shop replaced it for me. Since then I noticed that the clutch squeels intermittently. I also noticed a little bit of brake fluid dripping from the bellhousing. I'm assuming somebody screwed up with the slave cylinder. But what would make it squeel? Clutch works as it should and doesn't slip. Any ideas? Thanks
Check the 01 FSM on putfile. I think master and slave are replaced as a unit. Let the shop deal with it if they did the work. If their install caused fluid to contaminate the disk, make them replace that also. Perhaps watch them do the work.
Squeal could also be pilot bearing or throw out bearing.
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Fishbait
Jun 6, 2006 12:34 PM
