seat belt and dome light!!!
Help I have 2 99 quad cabs with seat belt problems.
1st. seat belt light will come on every half hour and the seat belts will lock, the only way to release them is to open the door. Then it is ok for another 1/2 hr. 2nd. the dome light doesn't come on when you open the door but the map lights do! The seatbelt will not release till you turn the key to run. So far: I've tried a new CTM and changed around the seatbelt sensor under the center seat. I've checked all fuses and wiring that I could find. One truck has power when you turn the key on and the other seems to run off the timer for 30 minutes but no key power. Any ideas!?! |
Help!!! I'd really like to figure these out.
have you tried the connections under the seats or the wiring harness to make sure you haven't cut the wire with the seat.
Does any one have a wiring diagram for the seat belt system?? |
So far I've tried the CTM, seat belt module under the center seat and the light switch! What next the air bag module under the center console?
Any Ideas??? When I turn the dome light switch off the seat belts release?? ***!! |
