Replacing Tie Rod Ends
Old Feb 12, 2009 | 02:14 PM
TankerIP's Avatar
I'm going to attempt to replace my inner tie rod ends with replacements from Autozone. Firestone told me they were loose and it would cost $450 plus alignment fee to replace. These things are really less than $50 each. I wonder if they were really that bad, but I want to get the truck aligned to help the new tires last as long as they can. So I will do this and take it somewhere for alignment.
A question: These replacements have a grease fitting. The originals do not. I wonder if there is enough space between the tie rod grease fitting and the frame to get a grease gun nozzle in there? There are no instructions that come with these parts. Any one else have experience with this?
Old Feb 12, 2009 | 02:22 PM
ratman46's Avatar
grease fittings
yep do it your self, its simple if u have the skills, the fittings will clear no problem just did mine, definitly get truck alighned dont count the threads it doesnt work good luck, ratman
Old Feb 12, 2009 | 04:17 PM
Wicked500R's Avatar
I replace everything from the box to the wheels on my 95' and did a self alignment with a tape measure and 2 4' levels...
Old Feb 15, 2009 | 07:48 AM
fschiola's Avatar
Take a look and see if you replace the zerk fittings with a 45 or 90 degree fitting, will allow you to access them easier.
ddestruel
Dec 7, 2008 06:37 AM
MnTom
Oct 25, 2004 06:03 PM
doug
May 24, 2003 08:55 AM
powerwagon440
May 1, 2003 05:20 PM
