Rear leaf helper springs
Old Jan 18, 2010 | 02:03 PM
jethroish's Avatar
If this needs to be moved to the towing folder, sorry. Was not sure which to put it in.
I have a 2002 Ram 2500. I used to tow a 5th wheel trailer that was 6500# max.
I got rid of that and now have a 24 foot, 3 horse living quarter trailer that weighs out at 7850# empty. Do not plan to ever put 3 horses in it. Just 2 horses with a little extra room for storage if needed.
Truck pulls it just fine, but looks like it is sitting just a hair too low in the rear.
Will these do the trick? anyone use these? Happy or no?
http://www.oreillyauto.com/site/c/de...0146&ppt=C0385
Old Jan 18, 2010 | 02:25 PM
Load Hauler 04's Avatar
What I find works the best and retains the stock ride when empty is aftermarket air bags. My wifes 2500 CC 4X4 Rides like a dream when empty but when you pull a trailer, the front end lookes at the sky, soluition, 5000 lb. air bags. I got mine thru styling trucks, the whole system with compressor was about 700.00. Well worth it
Old Jan 18, 2010 | 02:27 PM
SIXSLUG's Avatar
I was also going to suggest airbags. They will be my next modification to my truck.
Kurt
Old Jan 18, 2010 | 03:01 PM
jethroish's Avatar
Thanks for the replies. I found out through contacting Superior Automotive (they make helper leafs) that the ones in my first post will not work because they interfere with the factory overloads. If I want to use bolt on helper springs, I need a set of over-the-leaf helpers not the under-the-leaf indicated earlier.
I'll look into the air bags, but don't know if I want to dig that deep into the wallet.
Old Jan 18, 2010 | 03:12 PM
surfram's Avatar
I run a set of Timbrens on my 2004 2500. I installed mine without the optional spacers so they only engage with a decent load on the truck. They are not adjustable like airbags but are much cheaper than an airbag/compressor combo. Truckspring has kits from $194 to $229: http://www.truckspring.com/VSearchRe...&pt=189&fv=584
Old Jan 18, 2010 | 05:05 PM
nickg's Avatar
I have airbags as well (firestone) you can buy just the kit, its only around 250$ canadian, that does not include an air compressor, you dont need one any waythe onboad air adds a huge price tag to the cost
you just air them up as you require the extra lift, one of the little electric aircompressors(20$) that you toss in the trunk works just fine
My advice is to ditch the overloads and install the airbags
Old Jan 18, 2010 | 10:48 PM
VICIOUS FISHER's Avatar
I have ride rite airbags, factory 4" lift and overloads, no compressor, works fine and was cheap, every time I show up at the gravel pit and put 4,400 lbs of gravel in (almost 2 metric tonnes) the scalers look at the truck and say.....Is that a one ton, I say no, and he says wow, (there is zero squat) ya ya I know...I'm over, but It's not far home. It's not a problem changing the air for different applications, 20lbs for daily drivin and 60 for towing with moderate tongue weight. 90 for haulin big *** loads. worth every penny. I tow a 6500LB trailer and a 10,000lb trailer not daily but when i do if the bags aren't right on the road there's a gas station on every corner.
I bought a kit in that sat on the old jounce bumper mounts inboard of the springs.
Old Jan 19, 2010 | 09:02 AM
shorthair's Avatar
+1 on the air bags you can let them down to 10 psi when MT & bump 'em up to what ever you need when loaded to maintain ride quality.
fordrescueunit
17
Apr 15, 2012 11:49 AM
turbo246
18
Dec 9, 2010 10:22 AM
97catintenn
May 28, 2010 08:29 PM
95turbo4wd
Dec 12, 2007 05:59 PM
99 cummins
Feb 21, 2004 09:15 AM
