Rear Brakes
Old Jan 25, 2005 | 08:46 AM
Flashman's Avatar
Rear Brakes
I read in this forum that the 1 ton's larger brake shoe will fit the 3/4 ton's drum. (1998 24 valve). Can anyone confirm this?
Also I want to change out the rear brake cylinder for the Chebby 1 ton, again I have read this on this forum as a way to upgrade the rear brakes. What year Chebby cylinder do I need?
Old Jan 25, 2005 | 09:21 AM
infidel's Avatar
Use the Napa #4637337 cylinders. Just give them the number, they don't need to know what it goes on, just seems to just confuse them. I've talked to a few folks who have said the number crosses over at other auto parts stores.
Old Jan 25, 2005 | 09:38 PM
MNorby's Avatar
On a service truck that weighs 15,000 pounds loaded with tools and etc put the large GM 1-ton cylinders on and what a difference. Deffinately worth it and that napa number crossed no prob at Carquest.
Old Jan 26, 2005 | 04:14 PM
INJECTOR JACK's Avatar
It works on 1st gens but not 2nd gens. Do the wheel cylinder swap it is worth the time and money!
Old Jan 26, 2005 | 04:50 PM
ratsun's Avatar
I dont think the 1 ton shoes fit a 3/4 but the wheel cyls are a must do item.
Old Feb 23, 2005 | 08:23 PM
Mikedeere's Avatar
I did the chevy 1 ton wheel cyl. no problem, except!! when I got the wheel cylinders one was the right style, the other one was`nt. Aparently there are two styles because I called two other stores before I found the right one so be sure to check before you tear it down. The one we need has the rubber boot pressed on the inside like the dodge, some have the boot on the outside of the cyl. won`t fit.
1992 Renegade
Oct 11, 2014 03:29 PM
2500CTD
Oct 19, 2010 07:10 PM
wildcargo
Nov 29, 2005 04:20 AM
JImbo1
13
Apr 18, 2003 06:44 AM
