rear brake removal
Rear brake removal (Ford style rear brakes)
Ok I got the 1 ton rear cylinders that were supposed to go on today during the tire rotation. Pulled the rear drums off and They dont look like "normal" brakes. Went to autozone and looked it up in a haynes. No luck my brakes are pictured. The biggest thing is the return spring. It looks like only one return spring and it goes from one shoe to the other. The top pin, where the normal 2 return springs attach to, looks like a bolt there is a nut on the backside of the backing plate. Because of that I cant figure out how to remove the parking brake lever off. Anyone have pics or can email the brake pages from the FSM???I think the truck is winning
The wheel cyl deal thats talked about here stops at the 99 year model. You have a Kelseh-Hayes(Ford type) system and I don't think you need it. The wheel cyls you bought will not fit anyway.
Originally posted by firestorm
I too was going to upgrade to the cheby wheel cylinders, and Ram 3500 shoes. Is this what you are refering to?
I found this page http://home.comcast.net/~dieselford/brakes_rear.html that shows my brakes. Anyone else' look like these:
Ok got the rear cylinders on, didnt test drive it yet, gotta go to parts store. (is that bad if the test drive for one vehilce is to get parts for the other project ) The napa wheel cylinders are bigger. Turned the return spring upside down and it cleared the cylinder. My brakes resemble the one in the pic above, just dont have to remove axle to get to brakes. Other than that it was a simple swap. Hardest thing was having to tweak the brake lines a bit.
sorry about the delay. Yip the brakes rock now! Wierd to describe but the truck swats down when I hit the brakes instead of doing a nose dive. The better half and I both had to relearn the brakes on the truck. I recommend it.
HUNTINNUT
07-27-2013 11:40 AM
trik396
06-01-2008 07:04 PM
