Random no charge
Old Nov 25, 2025 | 08:53 AM
cougar's Avatar
Random no charge
01.5 24V auto. This has plagued me sense I got the truck. I've replaced the alternator twice and gone through the wiring including the grounds. Being intermittent, it is hard to trace. It occurred most often during startup, but not always like stuck brushes in the alternator, thus the replacements. A code scan shows low voltage with no other codes. Anyone have any suggestions?
Old Nov 25, 2025 | 09:19 AM
codes?
What does the multimeter show at the terminals, running, and not?
Old Nov 25, 2025 | 05:38 PM
texasprd's Avatar
Is the tach working when it seems not to be charging? Also, since the PCM controls charging, you could have a wiring issue going to/from the PCM. If you have a scan tool that lets you control alternator fielding, you can use the scan tool to force fielding and verify the wiring. I don't know if 98.5-02 has a battery temperature sensor, but if so - that can be a problem.
Old Nov 26, 2025 | 09:07 AM
cougar's Avatar
Originally Posted by NJTman
codes?
Normal battery voltages on battery and cable ends. 12v not running, 14v running. When it fails it is 11v or less and slowly drops. Cables are new. The only code translates to low voltage.
The tach works along with everything else as normal. No battery temp sensor. My scan tool is basic, all it can do is read some codes. The problem is intermittent, so catching it the act as they say is impossible.
masterphreak
Jun 12, 2017 05:00 AM
cginwyo
Sep 29, 2015 08:53 AM
boosted7
Oct 7, 2011 08:59 AM
litefoot
Jan 3, 2011 11:26 PM
sdseva
Jan 16, 2010 04:50 PM
