Radiatior Drain????
Old Nov 2, 2003 | 09:44 AM
HammerDown's Avatar
Radiatior Drain????
Hi all, I went to drain the coolant in my neighbors 99 2500 Cummins. The only drain I saw was at the lower driver side of the Radiator (correct)?.....it would only turn 1/4 way, but nothing comes out!
Am I missing something here with this drain valve?
Thanks for any suggestions.
Old Nov 2, 2003 | 10:16 AM
sherod's Avatar
Re:Radiatior Drain????
No, thats it. These things a bad about sticking shut. Turn it back and forth while pulling a lttle bit and you will get it. But, it does drain slow. By the way, you are right. It is a quarter turn.
Ed
Old Nov 2, 2003 | 01:37 PM
amartinson's Avatar
Remember to remove the radiatior cap to help it drain a little faster.
Old Nov 2, 2003 | 01:43 PM
BAD HABIT's Avatar
If I remember correctly. After the 1/4 turn, it pulls out quit a bit and will drain better.
Old Nov 2, 2003 | 02:23 PM
Haulin_in_Dixie's Avatar
Do yourself a favor and pick up a new O ring for it. They break easily and then leak. A torqueflite dipstick tube O ring works if you can get that easier.
Old Nov 2, 2003 | 04:02 PM
HammerDown's Avatar
Thanks for the tips guys...I did prod the hole with a thin wire to see it there was a clog stoping flow...but nothing. I even warmed the engine as to build some pressure in the system and force out coolant...still nothing.
So you suggest to pull the valve "out" some?
I'll try that tomorrow morning.
Thanks again...Ray.
Old Nov 2, 2003 | 04:47 PM
[quote author=HammerDown link=board=5;threadid=21866;start=0#msg204674 date=1067810531]
Thanks again...Ray.
[/quote]
Turning it to clear the plastic threads, you can pull it all the way out, has an O ring on the end. Best to pullit and at least check the O ring.
Old Nov 2, 2003 | 06:11 PM
HammerDown's Avatar
[quote author=Haulin in Dixie link
Do you mean turn it (froce it) "past the 1/4" where it stops? Or turn it the 1/4 turn and pull it out of it's housing?
Last thing i want to do is tear up my neighbors radatior.
PS. this valve turned clockwise 1/4".
Thanks ...
Old Nov 2, 2003 | 07:19 PM
Turn it the 1/4 turn counterclockwise and pull and turn, it will come out. Don't force too much but it will come out.
Old Nov 2, 2003 | 08:15 PM
HammerDown's Avatar
OK, thanks...will give that a try.
Old Nov 3, 2003 | 02:01 PM
HammerDown's Avatar
Thanks for all the tips...I got the valve to flow, jacked the back of the truck up, and also removed the lower radiator hose.
mikesr83@hotmai
Jun 22, 2012 10:21 AM
klx650a2
Jan 10, 2008 12:08 AM
wooff
May 1, 2003 11:22 AM
cpermd
Oct 28, 2002 02:19 PM
