Quad Cab Door
THE INSIDE DOORHANDLE FOR THE QC IS NOT WORKING:( I OPENED THE HANDLE ON THE DOOR JAM IT LOOKS LIKE A CABLE WITH A PLASTIC COLLAR ON IT AS BROKE HAS ANYONE HAD THIS HAPPEN TO THEM AND HOW MUCH $ WAS IT TO FIX
Welcome to DTR. Most likely the collar on the cable broke and you'll need to replace it. I believe the part is around 30 dollars. All you need to do is to pull the panel and it's a pretty straight forward repair.
thanks for your help J.:cool:
sometimes the turnbuckle that holds the 2 cables gets loose, happened to mine alot.
might want to check that first before ya buy a new one |
