Pillar trim
Old Mar 1, 2010 | 12:37 AM
Cam73's Avatar
Pillar trim
Hey guys-
The previous owner broke groove the retainer clips slide into on the driverside a-pillar trim. It's been epoxied several times but may need to be replaced. I was wondering if anyone knew where I could order one on line in tan? Thanks
Old Mar 1, 2010 | 08:04 AM
high bid's Avatar
Order any color, go to NAPA and get the Cummins tan engine spray paint and it should match almost perfect. It worked well when I painted my gauge pillar.
Old Mar 1, 2010 | 12:49 PM
SIXSLUG's Avatar
I believe the a-pillar trim is made from abs plastic. Mine was broken like you described and I glued it up with a sliver of abs plumbing pipe as a backer tab.
You may see if somebody on here has one laying around from replacing it with a guaged one...just a thought.
Old Mar 1, 2010 | 07:22 PM
Cam73's Avatar
Are the gauged pillars a full replacement?
I'm currently running a quadzilla commander but do to several failed attempts by quadzilla to fix problems with the unit, it will be discarded when funds allow for a more reliable monitoring system. I've got some digital gauges in mind that would work well in a pillar mount.
If the gauged ones are not an overlay I think I'll have no problem waiting until I change over.
Old Mar 2, 2010 | 02:47 PM
WestTN's Avatar
Go to Genos garage. They have gauge panels and the correct paint.
Old Mar 2, 2010 | 03:31 PM
SIXSLUG's Avatar
I have read that some are overlays, like mine, and others aren't or are installed without overlaying the original.
96 Ram man
Dec 22, 2007 01:16 PM
May 29, 2003 10:48 AM
doomgaze
Feb 6, 2003 08:37 PM
ozzie
Jan 16, 2003 08:41 PM
