Overhead console map lights
I've got a broken switch in my passenger side map light. Has anyone ever tried to get parts from Dodge for this?
http://www.jmers.com/images/DSC01248.JPG Basically the plastic top of the switch pops off and all of the legs that are supposed to secure it are broken. I've used super-glue to hold it on before, but that is starting to fail now. I figure that getting just the switch is out of the question, but I'm hoping I can replace just the assembly that holds the lights and switches. Anyone tried before? |
can't remember what I did on my last truck...I think I used JB weld....and it held out till I sold it.
Mine are broken too. thanks for posting that picture i need to fix mine this evening now that you mention it.
I rebuilt the broken legs w/epoxy something like JB Weld. It came in stick form. kneaded it intill mixed formed a new leg let it cure pilot drilled hole for screw reinstalled switch. Has held well for over a year.
me too
Aggiejustin,
I've got the same problem. Let us know if you find a source for the switch without buying the whole shebang. |
Breaking News!
I live a few miles from the factory that makes the switch, so I gave them a call. They will replace the switch for $24. Send the bad switch and a check or moneyorder in a padded envelope to:
Customer Service Judco Mfg Co 1429 W 240th St Harbor City CA 90710 That's a lot for a little switch, but it's gotta be way less than the dealer. |
mine are also broken on my 2nd gen and my dealer said and showed me the pc monitor where it said discountinued, and no dealer in the us had the console which is what you would replace if it was from the dealership, i do have a used one that im selling with the compass,and ambient temp sensor and the lights are in perfect condition. i learned the hardway if you don't have the compass/temp sensor the lights will not just switch over different wiring setup.
Hot melt glue gun
the switches are trash I wired in a pull switch the factory one are made to last
just off the lot[verymad] |
Related questions. I figure it's better than starting a new thread.
My Dad drives an '01 1500 and my Uncle just got an '01 2500 Cummins. Both trucks are rather abused. Neither truck has any interior lights via door opening or switching. And the 2500 has no outside running lights. 4 ways work and I presume brake lights work although I was testing by myself. I replaced 3 blown fuses and it made no difference. When you turn the headlight switch to park, the dash board dings at you. I'd really like a heads up on how to get the interior lights up in the 1500. |
Originally Posted by blackimpala
(Post 2035148)
Mine broke, so I bypassed the POS push switches, and mounted a toggle switch through the grey housing.
Originally Posted by Flashman
(Post 2037570)
Bump (for my question)
Originally Posted by Dangerous Dave
(Post 2037655)
On topic, I had mine break and I melted the plastic back together. I heated up a flathead screwdriver on the stove and used it like a soldering iron to melt the pieces back together. Its been good for a couple of years but I'm very gentle when turning the map lights on now. John |
