not charging
not charging
hi im brandon im new to the diesel and i have a 98 dodge 3/4 ton with a 24 valve. welll the problem is the altrnator isnt charging and i checked alll fuses battery and alternator and all wiring seem to be ok but i was wondering could a crank position sensor caues the problem cause i got a check engine light and it says cps sensor? any help or advice would greatly be appreciated
o ok.... im not sure about the cruise but it does jump out of od to 3rd gear then back to od alot would the cps and cause that problem to and ill replace the cps tomorrow and thanks for the help man very much appreciated
OD in/out/in/out
Do not put any grease or oil on the terminals, it will become restistance and create additional problems.
Hope this helps. Good luck.
Exturnal reg
http://dodgeforum.com/forum/2nd-gen-...onversion.html
Floyd
the tranny was hunting berfore i even had a charging problem and as for the batteries are brand new and so is the alternator and all cables and wires seem to be ok
o i know they do and batteries are good already test them and ill test the alternatorto make sure but i believe its the cps i had the check engine light on and it said cps so ill try that first and update yall
Diesel-Dan
20
09-22-2019 09:34 PM
GLHS
02-25-2011 10:12 PM
