no cruise
I have a 97 with a auto. I have no power to the switch in the steering wheel. I have replaced the switch, the servo, new vacumn lines. Can not find a fuse for the cruise anywhere marked cruise,it worked one day and notting the next.thanks
Re:no cruise
The only thing regarding the cruise that I have heard of is the line that runs under the driver side battery. I guess the battery can leak and cause this line to go bad.
Is the anti lock brake lite on?
I had the same problem only my anti lock brake lite came on and the speedo didn't work. I had some thing fly up on the road and smask the connector on the rear Diff.
:D Al |
I believe the power goes through the brake light on its way to the steering wheel. Also, the clockspring in the column can fail.
Sorry, meant to say brake light SWITCH.
Dave |
I had to have my column rewired when my cruise went out. Using the tilt wheel stressed and broke the wires. Then the horn hinked when I used the tilt
