No A/C No Tach No Alternator chargeing
Old 10-10-2017, 01:32 PM
YSTransport's Avatar
I have a 95 Dodge 5.9L with 148,000 I have lost my A/C,Tach,and alternator any ideas on what has caused this.
Old 10-10-2017, 08:47 PM
Received 2,392 Likes on 1,576 Posts
PCM failure is a likely cause.
Do you have the wait to start feature when it is cold, still?
If auto does the OD still work?
Welcome to DTR.
Old 10-11-2017, 08:57 AM
Yes I do still have my wait to start and its a Manual
Old 10-11-2017, 11:33 AM
texasprd's Avatar
IIRC, failure of the Engine Speed Sensor (ESS) or related wiring will cause those symptoms. If the PCM isn't getting an ESS signal, it doesn't know the engine is running so there is no A/C, no tach, no charging.
nothingbutdarts (10-11-2017)
Old 10-12-2017, 08:59 AM
patdaly's Avatar
Yep, also check the connector for the ESS, sometimes oil gets in there and will short across pins, take it apart, clean both sides out well with contact cleaner and it might just start working, I have had that work twice now.
Connector is up near the top of the timing cover, passenger side.
Old 10-18-2017, 02:36 PM
I replaced the PCM and the ESS and still the same results any other ideas?
Old 10-23-2017, 11:06 AM
texasprd's Avatar
Replacing the PCM is the very last resort. Did you check and clean the ESS connector, as Pat mentioned? And did you check all the wiring from that point back to the PCM, as I mentioned in my earlier post? It's very possible you have a broken wire or a wire that has rubbed through and may be grounding. You need to do visual and multimeter checks, which means you'll need to disconnect the harness from the PCM and check the pins for the ESS on the connector.
Do you have access to wiring diagrams?
Old 10-24-2017, 04:30 PM
I do not have access to wiring diagrams. Do you know where I could locate them?
Old 10-25-2017, 09:06 AM
texasprd's Avatar
I have individual-vehicle subscriptions to alldatadiy.com, which has wiring diagrams. Genos Garage has the actual manuals
Old 11-07-2017, 09:21 AM
texasprd's Avatar
Any resolution on your problem?
Old 11-09-2017, 10:51 PM
Vendor - Former Vendor
ecmexchange's Avatar
I was wondering the same thing. Any solution?
Old 04-25-2018, 04:05 PM
After removing all the wiring harness there was a broke ground between the battery and the Pcm once that connection was fixed everything went back to working perfectly. The truck runs good as new.
67HotRod (04-25-2018)
joem
12-28-2014 12:57 PM
5.9Excursion
03-13-2008 07:08 AM
edwinsmith
04-14-2005 03:44 PM
warden
02-09-2004 10:29 AM
feets
03-17-2003 09:57 AM
Quick Reply: No A/C No Tach No Alternator chargeing
