-   2nd Gen. Dodge Ram - No Drivetrain (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/)
-   -   Multi Function Switch (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/multi-function-switch-131493/)
Tsutter Jan 10, 2007 02:14 AM
Anybody know where to get a new Multi Function switch (the turn signal dimmer) besides the dealer. My buddy needs one for his 1997 dodge 1500.
infidel Jan 10, 2007 09:57 AM
Have you tried an autoparts store?
dhvaughan Jan 16, 2007 08:27 PM
autozone. $42.
mcoleman Jan 18, 2007 07:57 AM
Yep, Bought mine at Oreilly's. You'll also need the torx bits with the hole in them. I already had a set. can't remember the name at the moment but a standard torx won't work.
sixguns Jan 18, 2007 05:53 PM
tamper proof torx
dhvaughan Jan 19, 2007 07:26 PM
Originally Posted by sixguns (Post 1307451)
tamper proof torx
autozone $9 for a kit of various sizes including the one you need.
the screws you will take out are VERY long, and your wrench space is tight, and it takes a long time to get them out. replace them with either regular torx or allen head. you will need 2 or 3, i think 4mm, about 3/4 - 1 inch long.
TIP.. while you are there, if you want to disable the door open/key in switch dinging, unplug the little 2 wire connector to the ignition switch.
