Melted Headlight Switch Connector!
I had the same problem with a '93 250, like smokee said, seemed to be when I kept the dash lights turned down low. I just stripped back the wires and used crimp on 1/4" spade connectors to hook to the individual connectors on the new switch. Without all the extra plastic it seems to stay cool and work fine.
....you would use the blk/yl wire off the headlamp switch to trigger a relay. That way the relay would carry the amperage load, not the switch. Or....if you have trailer tow package, make sure any aftermarket of trailer lights are tapped into the "trailer tow running lamp circuit" which was the blk/orn wire as opposed the the blk/yel alot of people tapped into.
headlight switch
Hello All, I'm new to the party with the same problem on my 1992 W250. Parking and instrument lights went out at same time. Headlight switch toasted along with connector. Bought a replacement connector with pigtail from Advance, their PN: PT351. Bought a new headlight switch from them too, but quality is suspect (mine is defective out of the box). Might want to try a factory switch or one from NAPA. The replacement is straightforward. To get the **** off, there's a little button on the bottom of the switch (you'll have to locate it by feel) to push- then the ****- shaft and all, will slide out. Next step is to upgrade the lights with a new circuit and relays. There's an excellent step-by-step "how to" with pics on this forum.
Barryn
07-14-2008 09:30 AM
Pete Miller
02-21-2008 04:49 PM
jlipskoc
10-24-2005 01:16 PM
