Melted Headlight Switch Connector!
My 97 3500 Dually started having headlight switch light problems so I pulled the switch and discovered that the 9 pin plastic connector in the areas of the b2,h, and r pins had partially melted. The pink wire attached to b2 also was temp discolored. I need to replace the connector. Does Dodge service the connector without replacing the whole wire assy? Looks like a replacement of the connector and splice into existing wires would suffice, what do you say?
Richard
Richard
It should be covered by this recall> http://dodgeram.info/tsb/recalls/819.htm
They use a new switch and connector with short wires.
I believe the recall you are talking about does not apply to this rruck. Recall 819 applied only to 3500`s built through Oct. 21,1996 and my truck was built midway through 97. Obviously the same problems persisted past that recall point and Dodge is simply stuffing it! The kit is #CAJM8190 and I`ll probably see if the local dealer has it tomorrow. Thanks for the info,
Richard
Richard
Any chance that a "RV plug" was mounted in the bed of the truck? I often found that the wrong wire was tapped for the running lamps to the trailer and would cause this "meltdown". I've also seen people mount extra lights (running boards) to the circuit which can cause some issues.
There is a lot of comments in the owner manual about not using the parking light leads for powering other lights or aux. lighting. They suggest that you use a relay (30 amp) for all aux. lights...
Let us know if your dealer has the kit for the receptical that the switch plugs into[ the one that is burned] because when I tried to find one from our local dealer, the parts man gave me a song and dance that they only had a complete wiring harness at some rediculess price . I ended up using insulated crimp on connectors and just plugged them into the switch. That has worked very good so far on the 94. Also ran a seperate switch and relay to the trailer lights which probably helps to extend the life of the switch. I had the same problem on the 92 and fixed that one by going to the auto wreckers and removing the switch and socket from a dodge van and splicing that in. Either way is very low cost and works. Just takes a little labour.....
This morning I went to our local Dodge dealer in search of a connector! Found out that the connector was only available in a kit that included a switch, the connector with short 10" leads, and shrink tubing. The cost was 101.00 or so. I asked if the recall had ever been extended because my reasoning dictated that if my truck suffered from this malady at a build date of 7-97 then there has to be plenty of other 3500`s that are the same! He didn`t want to talk about it!! I bought the kit and left. Later today I installed the kit with good results, but to keep the same thing from happening again, I also ordered the Summit Harness kit to install. Should be here Thurs. or Fri.
I`m disappointed with Dodge`s response. The recall #819 vehicles all had(have) the same headlight switches as mine, no change even after the end of the recall! I`m fixing mine properly but there are many others out there that are in the same boat!
regards, Richard
regards, Richard
regards, Richard
regards, Richard
Also, I have found that these headlight switch connectors are starting to be serviced in the aftermarket.
Torquefan, excuse my ignorance but could you elaborate about installing a relay in the circuit that powers the parking light clearance light circuit? I would be very interested in doing so but don`t quite have the knowledge to do so.
Thanks,Richard
Thanks,Richard
There is a separate p/n for the head lamp switch connector that includes the plastic connector and pins. It's harder than he77 to find on the parts locator. I used to have the number in my notes, but that "issue" was long ago. If I found it I would gladly tell you the p/n and price.....but the powers that be would probably send me another nasty gram on "advertising in forums (non-vendor)" since I would be quoting a monetary amount.
....you would use the blk/yl wire off the headlamp switch to trigger a relay. That way the relay would carry the amperage load, not the switch. Or....if you have trailer tow package, make sure any aftermarket of trailer lights are tapped into the "trailer tow running lamp circuit" which was the blk/orn wire as opposed the the blk/yel alot of people tapped into.
Too bad about the recall. I did the relay thing before the recall came out, and although it was better, another connector burned out. I think that the problem is not really with the wiring, but with the rheostat for dimming the dash lights. If you drive for a long time with the lights dimmed, the switch gets hot and melts the connector.
george
george
