-   2nd Gen. Dodge Ram - No Drivetrain (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/)
-   -   Loosing wheel weights (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/loosing-wheel-weights-18125/)
redramnc Mar 21, 2003 08:37 AM
Just put on two new front tires and had to get 2 used rims to replace 2 warped ones (I knew they were not balancing out properly from the last rebalance). I checked the runout before using the rims and now one of the new rims is throwing weights off - three times as of yesterday. The used rims were bought out of the classifieds on this site and they are off a 98.5 that had aluminum rims put on it. Only one of the used rims is throwing the weights - the other is fine. I even had a second new tire put on the aggravating rim and it still threw the inside weights - even after imbalance matching the tire to the rim.<br><br>Has anybody else had problems with weights becoming self-removing? This is a first for me and I have many miles under me on D and E-rated tires over the years.<br><br>I now have stick-on weights inside the rim but they aren't quite as good a ride as wiehgts on the outside edge.
TBGH Mar 21, 2003 09:45 AM
Re:Loosing wheel weights
I have not experienced this. One of the local tire shops does use a liquid pink coloured fluid to balance &quot;difficult&quot; combinations. This works until you have a puncture and the fluid bows out.<br>John
