Location of fog light plug behind dash
I got the factory switch to wire my fog lights "Hella 1500's", I cant find the foam wrapped plug behind the dash to hook it up. anybody know how to trace it or were it might be. any help would be appreciated.
Mike
Mike
As far as I know your truck does not have the wiring unless it came from the factory with fog lights. When we sold the add on kits you also had to order the wiring kit which came with all wiring,relays, and the newe switch. I am pretty sure they are not pre-wired for the foglights.
TRAVIST
TRAVIST
My trucks had factory wiring for fogs to both sides of the bumper, wire colors were correct according to the service manual. For the life of me I couldn't find the other ends under the dash though.
Spent more time looking for them than it took to run one wire from the switch to trigger a relay mounted on the side of the battery holder. Inline fuse on a wire connected to the + battery terminal to the relay and some wire to the lights and I was set.
I read on fritz's dodgeram.org that if your truck came with the slt package the wiring is already there, I found the plug end under the radiator I just cant find the plug under the dash. Im trying to keep it as close to factory as I can.
Thanks!!
Mike
Thanks!!
Mike
stratos201proxl
01-23-2014 12:56 PM
ollie32
08-29-2008 08:44 AM
