How hard to replace control arms, end-links, and tie rod ends?
Old Jul 19, 2007 | 10:33 PM
wcbcruzer's Avatar
How hard would it be to replace the bushings in the control arms and sway bar end-links, as well as the tie rod ends? The control arms for example, if I pulled them one by one and replaced the bushings would it be a simple unbolt/re-bolt? Or do the arms get stubborn to remove?
Old Jul 20, 2007 | 06:09 PM
lews930's Avatar
yes they are stubborn. probably best to take off one at a time, otherwise you have to use a come a long to pull the axle backward to align the bolt holes. I used a porta power to do mine but had a jig to hold the arms. A heavy duty vice should take care of the sway bar bushings. heat the oold ones and they'll fall out. grease new ones for assembly
lewis
Old Jul 20, 2007 | 06:25 PM
wcbcruzer's Avatar
Thanks for the info. It'll be my first time doing these things. The come along is a good idea.
deaner5566
15
Sep 19, 2009 10:49 PM
ddestruel
Dec 7, 2008 06:37 AM
kennedy
Oct 10, 2007 11:30 PM
mr T
16
Feb 2, 2006 07:48 AM
